Salta al contenuto principale
Canon PowerShot A200 Batteries Replacement
  1. Canon PowerShot A200 Batteries Replacement, Outer Battery Cover: passo 1, immagine 1 di 2 Canon PowerShot A200 Batteries Replacement, Outer Battery Cover: passo 1, immagine 2 di 2
    • Place the camera so the battery cover is facing up, as shown in the picture.
    • Gently push on the outer battery cover until you hear a click, and then release.
  2. Canon PowerShot A200 Batteries Replacement, Inner Battery Cover: passo 2, immagine 1 di 2 Canon PowerShot A200 Batteries Replacement, Inner Battery Cover: passo 2, immagine 2 di 2
    • To open the inner battery cover, push down on the grey latch until you hear a click, and then release.
    • Remove the dead batteries from the camera.
  3. Canon PowerShot A200 Batteries Replacement, Replacing the Batteries: passo 3, immagine 1 di 1
    • After removing the batteries, insert the new batteries in the proper direction.
    • Now push the black, inner cover down until you hear a click to secure the batteries in place.
    • Push down and forward on the outer cover to secure the latch. Your camera will now be fully charged.
Conclusione
Congratulations, you're done.
Ellen Chambers
Membro da: 01/05/11
231 Reputazione
2 Guide realizzate
Cal Poly, Team 7-37, Regan Winter 2011 Membro di Cal Poly, Team 7-37, Regan Winter 2011
CPSU-REGAN-W11S7G37
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 16
Tutti i Tempi: 2,102
