Salta al contenuto principale
Canon PIXMA iP3600 Printhead Replacement
  1. Canon PIXMA iP3600 Printhead Replacement, Ink Cartridges: passo 1, immagine 1 di 1
    • Press the power button to turn on the printer.
  2. Canon PIXMA iP3600 Printhead Replacement: passo 2, immagine 1 di 1
    • Pull down the front output tray cover.
  3. Canon PIXMA iP3600 Printhead Replacement: passo 3, immagine 1 di 1
    • Lift the printer lid.
  4. Canon PIXMA iP3600 Printhead Replacement: passo 4, immagine 1 di 1
    • Allow the belt, containing ink cartridges, to adjust and center so that the ink cartridges are visible.
  5. Canon PIXMA iP3600 Printhead Replacement: passo 5, immagine 1 di 2 Canon PIXMA iP3600 Printhead Replacement: passo 5, immagine 2 di 2
    • Push in the white clip to release the ink cartridge from the printhead.
    • Lift the ink cartridge from the printhead.
    • Repeat this process for the remaining ink cartridges.
    • You have successfully removed all ink cartridges.
  6. Canon PIXMA iP3600 Printhead Replacement, Printhead: passo 6, immagine 1 di 1
    • After removing all ink cartridges, lift the printhead lock lever.
  7. Canon PIXMA iP3600 Printhead Replacement: passo 7, immagine 1 di 1
    • Pull up and lift out the black piece that previously held the ink cartridges. This is the printhead.
    Comment réparer la tête d'impression
    Mohamed el amine Baali - Replica
  8. Canon PIXMA iP3600 Printhead Replacement: passo 8, immagine 1 di 1
    • You have successfully removed your printhead.
Conclusione
Altre 5 persone hanno completato questa guida.
Caitlyn
Membro da: 10/07/14
1.184 Reputazione
4 Guide realizzate
USF Tampa, Team 1-3, Leahy Fall 2014 Membro di USF Tampa, Team 1-3, Leahy Fall 2014
USFT-LEAHY-F14S1G3
3 Membri
8 Guide realizzate
Un commento
fairly helpful, especially the photo's. but I need advice on how to clean the printhead before trying to replace it,
a1halber - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 50
Tutti i Tempi: 7,695
