Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Store
Introduzione
If your printed documents or images are becoming distorted due to a dysfunctional printhead, use this guide to replace the printhead.
  1. Press the power button to turn on the printer.
    • Press the power button to turn on the printer.
  2. Pull down the front output tray cover.
    • Pull down the front output tray cover.
  3. Lift the printer lid.
    • Lift the printer lid.
  4. Allow the belt, containing ink cartridges, to adjust and center so that the ink cartridges are visible.
    • Allow the belt, containing ink cartridges, to adjust and center so that the ink cartridges are visible.
  5. Push in the white clip to release the ink cartridge from the printhead. Lift the ink cartridge from the printhead.
    • Push in the white clip to release the ink cartridge from the printhead.
    • Lift the ink cartridge from the printhead.
    • Repeat this process for the remaining ink cartridges.
    • You have successfully removed all ink cartridges.
  6. After removing all ink cartridges, lift the printhead lock lever.
    • After removing all ink cartridges, lift the printhead lock lever.
  7. Pull up and lift out the black piece that previously held the ink cartridges. This is the printhead.
    • Pull up and lift out the black piece that previously held the ink cartridges. This is the printhead.
  8. You have successfully removed your printhead.
    • You have successfully removed your printhead.
Conclusione
Altre 3 persone hanno completato questa guida.
Caitlyn
Membro da: 07/10/2014
1.043 Reputazione
4 Guide realizzate
USF Tampa, Team 1-3, Leahy Fall 2014 Membro di USF Tampa, Team 1-3, Leahy Fall 2014
USFT-LEAHY-F14S1G3
3 Membri
4 Guide realizzate
fairly helpful, especially the photo's. but I need advice on how to clean the printhead before trying to replace it,
a1halber - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 30
Tutti i Tempi: 5,781
