Salta al contenuto principale
Canon PIXMA TS3300 Ink Cartridge Replacement
Cosa ti serve
  1. Canon PIXMA TS3300 Ink Cartridge Replacement, Ink Cartridge: passo 1, immagine 1 di 2 Canon PIXMA TS3300 Ink Cartridge Replacement, Ink Cartridge: passo 1, immagine 2 di 2
    • Press the power button in the top left corner to turn on the printer.
    • The light next to the button will turn green if the printer is on.
  2. Canon PIXMA TS3300 Ink Cartridge Replacement: passo 2, immagine 1 di 2 Canon PIXMA TS3300 Ink Cartridge Replacement: passo 2, immagine 2 di 2
    • Lift the cartridge compartment located in the front of the printer to gain access on the inside of the printer.
    • Allow for the cartridge holder to move into view.
  3. Canon PIXMA TS3300 Ink Cartridge Replacement: passo 3, immagine 1 di 2 Canon PIXMA TS3300 Ink Cartridge Replacement: passo 3, immagine 2 di 2
    • The cartridge should be located in the center of the printer.
    • Push down on the cartridge and pull it out.
  4. Canon PIXMA TS3300 Ink Cartridge Replacement: passo 4, immagine 1 di 2 Canon PIXMA TS3300 Ink Cartridge Replacement: passo 4, immagine 2 di 2
    • Prepare the new cartridge by peeling off the cover.
  5. Canon PIXMA TS3300 Ink Cartridge Replacement: passo 5, immagine 1 di 3 Canon PIXMA TS3300 Ink Cartridge Replacement: passo 5, immagine 2 di 3 Canon PIXMA TS3300 Ink Cartridge Replacement: passo 5, immagine 3 di 3
    • Peel off the orange sticker on the left side of the cartridge.
  6. Canon PIXMA TS3300 Ink Cartridge Replacement: passo 6, immagine 1 di 2 Canon PIXMA TS3300 Ink Cartridge Replacement: passo 6, immagine 2 di 2
    • Insert the cartridge at an angle to the cartridge holder.
    • Push upward on the cartridge until a clicking sound is heard.
  7. Canon PIXMA TS3300 Ink Cartridge Replacement: passo 7, immagine 1 di 1
    • Close the cartridge compartment cover.
    • The printer should make a sound from the cartridges going back to their resting position.
Conclusione
Allow for the cartridge holder to reposition and you are ready to print!
Altre 7 persone hanno completato questa guida.
3Commenti sulla guida
Hi if I replace the ink cartridge with a refill the printer has an error message E16 which I know means cartridge is out of ink. How do I override this message to keep printing. I have a Canon TS3360. Jenny.
Jenny - Replica
My Pixma TS3300 printer is giving an error message E14 since I replaced the empty cartridges with new 245XL and 246XL cartridges. These should be compatible but aren't working. Please help!
Susan Gardner - Replica
Alles geht soweit gut, nur wenn ich die gescannten Dokumente wieder ausdrucken möchte tut es nicht sonder geht in den Speicher, von da Versuche ich wiederum auszudrucken, es springt immer in gespeichert zurück.
Charlotte Suhrbier - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 14
Ultimi 7 Giorni: 91
Ultimi 30 Giorni: 394
Tutti i Tempi: 22,923
