Salta al contenuto principale
Canon PIXMA MP620B Command Screen Replacement
Val Fedorikhin
Val Fedorikhin e 3 altri collaboratori
Ultimo aggiornamento il 14 mar 2023
15 - 30 minuti
Facile
Introduzione
Vai al passo 1
Replacing the command screen is relatively simple. You will have to pop off a few parts from the lid section of the printer in order to get at the back part of the command screen. Once you have access to the command screen and the attached chip, you can unplug a few wires and remove the screen with a philips-head screwdriver. After you have removed the screen, put in a replacement and close the printer back up. Good Luck!
Cosa ti serve
Strumenti
  • Phillips #0 Screwdriver
  • Spudger
    Spudger
  1. Canon PIXMA MP620B Command Screen Replacement, Open Printer Lid: passo 1, immagine 1 di 1
    • Open top lid of the printer to reveal the scanner
  2. Canon PIXMA MP620B Command Screen Replacement, Pull apart the two large lid plates: passo 2, immagine 1 di 2 Canon PIXMA MP620B Command Screen Replacement, Pull apart the two large lid plates: passo 2, immagine 2 di 2
    • Insert the spudger tool into the top lid in between the blue and the black panels.
    • Use this tool to pry the two panels apart
  3. Canon PIXMA MP620B Command Screen Replacement, Take apart the two sections: passo 3, immagine 1 di 1
    • After these two panels are separated, set the top panel to the side for now
  4. Canon PIXMA MP620B Command Screen Replacement, Pull out wires leading to screen assembly: passo 4, immagine 1 di 1
    • Unplug the two wires shown at the right of the command screen
  5. Canon PIXMA MP620B Command Screen Replacement, Unscrew screen assembly: passo 5, immagine 1 di 1
    • Unscrew the four screws shown to detach the command screen from the printer
  6. Canon PIXMA MP620B Command Screen Replacement, Replace assembly: passo 6, immagine 1 di 1
    • Take the detached command screen off of the printer and replace.
Conclusione
Altre 4 persone hanno completato questa guida.
Preparati per le riparazioni future
Acquista tutti
Cal Poly, Team 6-21, Maness Fall 2014 Membro di Cal Poly, Team 6-21, Maness Fall 2014
CPSU-MANESS-F14S6G21
4 Membri
10 Guide realizzate
2Commenti sulla guida
Ideas as to where to buy replacement screen assembly?
davepi49 - Replica
same question
Jan de Ruiter -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 7
Tutti i Tempi: 1,505
