Salta al contenuto principale
Canon PIXMA MP190 Ink Cartridge Replacement
  1. Canon PIXMA MP190 Ink Cartridge  Replacement, Turn printer on.: passo 1, immagine 1 di 1
    • The printer needs to be on in order to change the ink cartridges.
  2. Canon PIXMA MP190 Ink Cartridge  Replacement, Locate Ink Cartridges: passo 2, immagine 1 di 3 Canon PIXMA MP190 Ink Cartridge  Replacement, Locate Ink Cartridges: passo 2, immagine 2 di 3 Canon PIXMA MP190 Ink Cartridge  Replacement, Locate Ink Cartridges: passo 2, immagine 3 di 3
    • To locate the ink cartridges the paper output tray must be in the lowered position.
    • Next lift the scanning unit until the scanning support is vertical.
    • Lower the scanning unit until the scanning unit support seats in the scanning unit support slot.
  3. Canon PIXMA MP190 Ink Cartridge  Replacement, Remove Ink Cartridge: passo 3, immagine 1 di 3 Canon PIXMA MP190 Ink Cartridge  Replacement, Remove Ink Cartridge: passo 3, immagine 2 di 3 Canon PIXMA MP190 Ink Cartridge  Replacement, Remove Ink Cartridge: passo 3, immagine 3 di 3
    • Allow the printer to position the ink cartridge carrier into the ink cartridge removal location.
    • Before replacing the ink cartridge ensure the correct ink cartridge is installed.
    • Push down on the front edge of the ink cartridge.
    • Observe the angle at which the ink cartridge is removed.
    • Grasp ink cartridge and pull up and out to remove.
Conclusione
Altre 4 persone hanno completato questa guida.
Michigan Tech, Team 1-5, Lauer Fall 2014 Membro di Michigan Tech, Team 1-5, Lauer Fall 2014
MTU-LAUER-F14S1G5
3 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 27
Tutti i Tempi: 9,633
