Salta al contenuto principale
Canon MF4700n Laser Toner Cartridge Replacement
Cosa ti serve
  1. Canon MF4700n Laser Toner Cartridge Replacement, Laser Toner Cartridge: passo 1, immagine 1 di 3 Canon MF4700n Laser Toner Cartridge Replacement, Laser Toner Cartridge: passo 1, immagine 2 di 3 Canon MF4700n Laser Toner Cartridge Replacement, Laser Toner Cartridge: passo 1, immagine 3 di 3
    • Turn off the printer.
    • Make sure that the energy saver button is not lit up. If it is, the printer needs to be turned off.
  2. Canon MF4700n Laser Toner Cartridge Replacement: passo 2, immagine 1 di 2 Canon MF4700n Laser Toner Cartridge Replacement: passo 2, immagine 2 di 2
    • Grab the operation panel and lift it up to reveal the toner cover.
    • Make sure there is nothing on top of the printer.
    • Potential for Device Damage: Forcing the operation panel to open may cause damage to the printer.
  3. Canon MF4700n Laser Toner Cartridge Replacement: passo 3, immagine 1 di 3 Canon MF4700n Laser Toner Cartridge Replacement: passo 3, immagine 2 di 3 Canon MF4700n Laser Toner Cartridge Replacement: passo 3, immagine 3 di 3
    • Open the toner cover to reveal the toner cartridge.
  4. Canon MF4700n Laser Toner Cartridge Replacement: passo 4, immagine 1 di 3 Canon MF4700n Laser Toner Cartridge Replacement: passo 4, immagine 2 di 3 Canon MF4700n Laser Toner Cartridge Replacement: passo 4, immagine 3 di 3
    • Grab the ledge of the cartridge and pull it out.
  5. Canon MF4700n Laser Toner Cartridge Replacement: passo 5, immagine 1 di 2 Canon MF4700n Laser Toner Cartridge Replacement: passo 5, immagine 2 di 2
    • Grab a new/working toner cartridge.
    • If the cartridge is new, then there will be plastic components on it. Follow the manual that comes with the new cartridge to remove the plastic components.
    • Shake the cartridge to distribute the toner evenly inside.
  6. Canon MF4700n Laser Toner Cartridge Replacement: passo 6, immagine 1 di 3 Canon MF4700n Laser Toner Cartridge Replacement: passo 6, immagine 2 di 3 Canon MF4700n Laser Toner Cartridge Replacement: passo 6, immagine 3 di 3
    • On both sides of the cartridge, there are two knobs sticking out.
    • Inside the toner cover, there are two toner guides, one on each side.
    • Align the knobs with the toner guides and push the cartridge securely all the way in.
  7. Canon MF4700n Laser Toner Cartridge Replacement: passo 7, immagine 1 di 3 Canon MF4700n Laser Toner Cartridge Replacement: passo 7, immagine 2 di 3 Canon MF4700n Laser Toner Cartridge Replacement: passo 7, immagine 3 di 3
    • Close the toner cover.
    • Lower the operation panel.
Conclusione
The Canon MF4700n Printer should print normally unless a different component is broken.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 33
Tutti i Tempi: 1,422
