Salta al contenuto principale
Canon ImageCLASS MF4350d Transformer Replacement
Cosa ti serve
    1. Canon ImageCLASS MF4350d Transformer Replacement, Front Paneling: passo 1, immagine 1 di 1
      • Lift the printer lid up as shown in the photo.
      Chiedi a FixBot
      Aggiungi Commento
    2. Canon ImageCLASS MF4350d Transformer Replacement: passo 2, immagine 1 di 2 Canon ImageCLASS MF4350d Transformer Replacement: passo 2, immagine 2 di 2
      • Locate and remove the two 10mm side screws. There is one on each side.
      Chiedi a FixBot
      Aggiungi Commento
    3. Canon ImageCLASS MF4350d Transformer Replacement: passo 3, immagine 1 di 2 Canon ImageCLASS MF4350d Transformer Replacement: passo 3, immagine 2 di 2
      • Unhook the plastic panel from the printer starting from the top.
      • You may need to wiggle the panel a bit to loosen it.
      • To remove the bottom part of the paneling gently lay the printer on its back.
      • The scanner lid needs to be supported when moving the printer
      Chiedi a FixBot
      Aggiungi Commento
    1. Canon ImageCLASS MF4350d Transformer Replacement, Right Side Paneling: passo 4, immagine 1 di 3 Canon ImageCLASS MF4350d Transformer Replacement, Right Side Paneling: passo 4, immagine 2 di 3 Canon ImageCLASS MF4350d Transformer Replacement, Right Side Paneling: passo 4, immagine 3 di 3
      • Gently unhook the right side paneling (as looking at the printer's front face) from the printer.
      • Use a gentle back and forth motion to wiggle the hooks out.
      Chiedi a FixBot
      Aggiungi Commento
    1. Canon ImageCLASS MF4350d Transformer Replacement, Transformer: passo 5, immagine 1 di 2 Canon ImageCLASS MF4350d Transformer Replacement, Transformer: passo 5, immagine 2 di 2
      • Locate the yellow wire connected to the metal box.
      • Carefully pull the yellow wire from the black connector.
      • Wires may detach completely from plug so tug very gently.
      Chiedi a FixBot
      Aggiungi Commento
    2. Canon ImageCLASS MF4350d Transformer Replacement: passo 6, immagine 1 di 2 Canon ImageCLASS MF4350d Transformer Replacement: passo 6, immagine 2 di 2
      • Locate the spring.
      • Unhook the spring on the side of the metal box.
      Chiedi a FixBot
      Aggiungi Commento
    3. Canon ImageCLASS MF4350d Transformer Replacement: passo 7, immagine 1 di 1
      • Unscrew the 10mm screw attaching the metal plate to the printer.
      Chiedi a FixBot
      Aggiungi Commento
    4. Canon ImageCLASS MF4350d Transformer Replacement: passo 8, immagine 1 di 1
      • Lift the transformer out of the printer.
      Chiedi a FixBot
      Aggiungi Commento
Conclusione
Cal Poly, Team 13-1, Forte Fall 2013 Membro di Cal Poly, Team 13-1, Forte Fall 2013
CPSU-FORTE-F13S13G1
5 Membri
16 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 7
Ultimi 30 giorni: 37
Tutti i Tempi: 3,502
