Salta al contenuto principale
Canon ImageCLASS MF4350d Remove Right Side Paneling
Cosa ti serve
  1. Canon ImageCLASS MF4350d Remove Right Side Paneling, Front Paneling: passo 1, immagine 1 di 1
    • Lift the printer lid up as shown in the photo.
  2. Canon ImageCLASS MF4350d Remove Right Side Paneling: passo 2, immagine 1 di 2 Canon ImageCLASS MF4350d Remove Right Side Paneling: passo 2, immagine 2 di 2
    • Locate and remove the two 10mm side screws. There is one on each side.
  3. Canon ImageCLASS MF4350d Remove Right Side Paneling: passo 3, immagine 1 di 2 Canon ImageCLASS MF4350d Remove Right Side Paneling: passo 3, immagine 2 di 2
    • Unhook the plastic panel from the printer starting from the top.
    • You may need to wiggle the panel a bit to loosen it.
    • To remove the bottom part of the paneling gently lay the printer on its back.
    • The scanner lid needs to be supported when moving the printer
  4. Canon ImageCLASS MF4350d Remove Right Side Paneling, Right Side Paneling: passo 4, immagine 1 di 3 Canon ImageCLASS MF4350d Remove Right Side Paneling, Right Side Paneling: passo 4, immagine 2 di 3 Canon ImageCLASS MF4350d Remove Right Side Paneling, Right Side Paneling: passo 4, immagine 3 di 3
    • Gently unhook the right side paneling (as looking at the printer's front face) from the printer.
    • Use a gentle back and forth motion to wiggle the hooks out.
Conclusione
Altre 3 persone hanno completato questa guida.
Helena Yanez
Membro da: 09/29/13
461 Reputazione
4 Guide realizzate
Cal Poly, Team 13-1, Forte Fall 2013 Membro di Cal Poly, Team 13-1, Forte Fall 2013
CPSU-FORTE-F13S13G1
5 Membri
16 Guide realizzate
1Commento della guida
Tore paper when removing jamed paper. A small piece of paper must still be in machine.
Louis Pike McCasland - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 16
Tutti i Tempi: 4,624
