Salta al contenuto principale
Canon FS30 LCD Screen Replacement
Cosa ti serve
  1. Canon FS30 LCD Screen Replacement, LCD Screen: passo 1, immagine 1 di 2 Canon FS30 LCD Screen Replacement, LCD Screen: passo 1, immagine 2 di 2
    • Locate battery compartment cover. Turn the device over and locate the battery compartment cover.
    • Place a finger or thumb on the textured section of the battery compartment cover and push forward until you hear a click. Then lift the battery compartment cover.
  2. Canon FS30 LCD Screen Replacement: passo 2, immagine 1 di 2 Canon FS30 LCD Screen Replacement: passo 2, immagine 2 di 2
    • Locate the grey latch and move it aside. The battery is spring loaded and will pop up.
    • Remove the battery.
  3. Canon FS30 LCD Screen Replacement: passo 3, immagine 1 di 2 Canon FS30 LCD Screen Replacement: passo 3, immagine 2 di 2
    • Using the Phillips #000, remove the two screws on the LCD panel.
    • Using the Phillips #000, remove two more screws near the LCD panel swivel point.
  4. Canon FS30 LCD Screen Replacement: passo 4, immagine 1 di 2 Canon FS30 LCD Screen Replacement: passo 4, immagine 2 di 2
    • Use the plastic opening tool to remove the plastic cover from the LCD panel.
  5. Canon FS30 LCD Screen Replacement: passo 5, immagine 1 di 2 Canon FS30 LCD Screen Replacement: passo 5, immagine 2 di 2
    • Locate and remove two screws on the logic board.
    • Use the plastic opening tool to open the ZIF (zero insertion force) connector. The LCD ribbon should pop up.
  6. Canon FS30 LCD Screen Replacement: passo 6, immagine 1 di 2 Canon FS30 LCD Screen Replacement: passo 6, immagine 2 di 2
    • Locate the LCD screen underneath the logic board and slide it out.
Conclusione
USF Tampa, Team S1-G4, Nance Spring 2017 Membro di USF Tampa, Team S1-G4, Nance Spring 2017
USFT-NANCE-S17S1G4
4 Membri
10 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 8
Tutti i Tempi: 523
