Salta al contenuto principale
Canon EOS Rebel XTi Memory Card Replacement
Cosa ti serve
  1. Canon EOS Rebel XTi Memory Card Replacement, Memory Card: passo 1, immagine 1 di 1
    • Place the camera on its side with the soft touch grip facing up and the top of the camera facing right.
  2. Canon EOS Rebel XTi Memory Card Replacement: passo 2, immagine 1 di 1
    • Slide the memory card door in the direction of the arrow engraved on the camera.
    • Once the door has slid open to its full position, lift up on the door.
  3. Canon EOS Rebel XTi Memory Card Replacement: passo 3, immagine 1 di 1
    • With the door open, push down the small black plunger next to the CF slot. The CF card will disengage from the slot and be ejected far enough that you can grasp it between thumb and forefinger and remove it from the slot.
    • The plunger will stay in its depressed position until a CF card is again inserted in the slot.
Conclusione
USF Tampa, Team 8-6, Eyestone Fall 2015 Membro di USF Tampa, Team 8-6, Eyestone Fall 2015
USFT-EYESTONE-F15S8G6
3 Membri
18 Guide realizzate
Un commento
My camara wont read memory card
mcbed215 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 29
Tutti i Tempi: 2,978
