Salta al contenuto principale
Canon EOS Rebel XTi Flash Module Replacement
Cosa ti serve
  1. Canon EOS Rebel XTi Flash Module Replacement, Battery: passo 1, immagine 1 di 1
    • Place the camera upside down, and position it to where the back of the camera is visible.
  2. Canon EOS Rebel XTi Flash Module Replacement: passo 2, immagine 1 di 1
    • Pull the orange tab to the right to release the primary battery.
  3. Canon EOS Rebel XTi Flash Module Replacement: passo 3, immagine 1 di 1
    • To remove the secondary battery, reposition the camera to where the display screen is facing upwards.
    • Place your finger inside the empty battery compartment and pull away from the camera on the ridged battery tab.
    I have the rebel xti as well, and have the same issue, and i have 2 new primary batteries, and 1 new secondary battery, and 1 new charger, yet the camera, still will not turn on. So, if not the battery or the battery charger, what could be the problem? Ty
    Rich Irons - Replica
    I had no idea my camera had a second battery!
    Terri - Replica
  4. Canon EOS Rebel XTi Flash Module Replacement, Memory Card: passo 4, immagine 1 di 1
    • Place the camera on its side with the soft touch grip facing up and the top of the camera facing right.
  5. Canon EOS Rebel XTi Flash Module Replacement: passo 5, immagine 1 di 1
    • Slide the memory card door in the direction of the arrow engraved on the camera.
    • Once the door has slid open to its full position, lift up on the door.
  6. Canon EOS Rebel XTi Flash Module Replacement: passo 6, immagine 1 di 1
    • With the door open, push down the small black plunger next to the CF slot. The CF card will disengage from the slot and be ejected far enough that you can grasp it between thumb and forefinger and remove it from the slot.
    • The plunger will stay in its depressed position until a CF card is again inserted in the slot.
  7. Canon EOS Rebel XTi Flash Module Replacement, Top Casing: passo 7, immagine 1 di 3 Canon EOS Rebel XTi Flash Module Replacement, Top Casing: passo 7, immagine 2 di 3 Canon EOS Rebel XTi Flash Module Replacement, Top Casing: passo 7, immagine 3 di 3
    • Remove the single 10 mm JIS #00 shoulder screw.
    • Remove the two 6 mm JIS #00 screws.
  8. Canon EOS Rebel XTi Flash Module Replacement: passo 8, immagine 1 di 1
    • Separate the top casing from the electrical components enough to expose the wire harnesses that will need to be disconnected.
    • Ensure to remove the casing gently. There are several wire harnesses connecting the motherboard to components on the casing.
  9. Canon EOS Rebel XTi Flash Module Replacement: passo 9, immagine 1 di 1
    • Unplug the yellow connector located on the top of the camera.
  10. Canon EOS Rebel XTi Flash Module Replacement: passo 10, immagine 1 di 1
    • Disconnect the red connector located by the USB port.
  11. Canon EOS Rebel XTi Flash Module Replacement, Flash Module: passo 11, immagine 1 di 1
    • Use a J00 screwdriver to remove the two 3 mm screws on the retention arms. There is one arm on each side of the module.
    • Do not lose the washers.
    • Remove the Retention Arms.
  12. Canon EOS Rebel XTi Flash Module Replacement: passo 12, immagine 1 di 2 Canon EOS Rebel XTi Flash Module Replacement: passo 12, immagine 2 di 2
    • Use a J00 screwdriver to remove the three 3 mm screws on the flash cap.
    • Remove the flash cap.
  13. Canon EOS Rebel XTi Flash Module Replacement: passo 13, immagine 1 di 2 Canon EOS Rebel XTi Flash Module Replacement: passo 13, immagine 2 di 2
    • Remove the 7 mm phillips head screw on the flash hinge.
    • Using the straight tweezers remove the spring from the hinge hole.
  14. Canon EOS Rebel XTi Flash Module Replacement: passo 14, immagine 1 di 1
    • Lift the side of the flash module closest to the on/off button towards the opposite side of the camera.
    • Pull the wires gently through the top of the camera to completely remove the flash module.
    • Be Gentle with the wires, even though they have already been disconnected when removing the top casing
Conclusione
Luis Calle
Membro da: 08/30/15
416 Reputazione
3 Guide realizzate
USF Tampa, Team 8-6, Eyestone Fall 2015 Membro di USF Tampa, Team 8-6, Eyestone Fall 2015
USFT-EYESTONE-F15S8G6
3 Membri
18 Guide realizzate
3 Commenti
What is the part number for the Module, or where can it be readily found?
Scott - Replica
You have got to be kidding me.. my camera would never get to shoot another photo...
ssneed -
Between steps 7 and 8, you left out removing the rest of the body covers. The top won't come off without removing the front, back, and sides.
Marvin Weaver - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 25
Tutti i Tempi: 2,319
