Introduzione
Prerequisite Only
Removing the casing from the camera is necessary to perform any sort of maintenance to the internals of the camera. Once the case is separated from the camera, make certain to be gentle and disconnect any wire harnesses to avoid damaging any components.
Cosa ti serve
Place the camera upside down, and position it to where the back of the camera is visible.
To remove the secondary battery, reposition the camera to where the display screen is facing upwards.
Place your finger inside the empty battery compartment and pull away from the camera on the ridged battery tab.
I have the rebel xti as well, and have the same issue, and i have 2 new primary batteries, and 1 new secondary battery, and 1 new charger, yet the camera, still will not turn on. So, if not the battery or the battery charger, what could be the problem? Ty
Place the camera on its side with the soft touch grip facing up and the top of the camera facing right.
Altre 4 persone hanno completato questa guida.
