Salta al contenuto principale
Canon EOS Rebel XTi Back Casing Replacement
Cosa ti serve
  1. Canon EOS Rebel XTi Back Casing Replacement, Battery: passo 1, immagine 1 di 1
    • Place the camera upside down, and position it to where the back of the camera is visible.
  2. Canon EOS Rebel XTi Back Casing Replacement: passo 2, immagine 1 di 1
    • Pull the orange tab to the right to release the primary battery.
  3. Canon EOS Rebel XTi Back Casing Replacement: passo 3, immagine 1 di 1
    • To remove the secondary battery, reposition the camera to where the display screen is facing upwards.
    • Place your finger inside the empty battery compartment and pull away from the camera on the ridged battery tab.
  4. Canon EOS Rebel XTi Back Casing Replacement, Memory Card: passo 4, immagine 1 di 1
    • Place the camera on its side with the soft touch grip facing up and the top of the camera facing right.
  5. Canon EOS Rebel XTi Back Casing Replacement: passo 5, immagine 1 di 1
    • Slide the memory card door in the direction of the arrow engraved on the camera.
    • Once the door has slid open to its full position, lift up on the door.
  6. Canon EOS Rebel XTi Back Casing Replacement: passo 6, immagine 1 di 1
    • With the door open, push down the small black plunger next to the CF slot. The CF card will disengage from the slot and be ejected far enough that you can grasp it between thumb and forefinger and remove it from the slot.
    • The plunger will stay in its depressed position until a CF card is again inserted in the slot.
  7. Canon EOS Rebel XTi Back Casing Replacement, Back Casing: passo 7, immagine 1 di 1
    • Remove the three black 4 mm JIS #0 screws on the bottom of the camera.
  8. Canon EOS Rebel XTi Back Casing Replacement: passo 8, immagine 1 di 2 Canon EOS Rebel XTi Back Casing Replacement: passo 8, immagine 2 di 2
    • Remove the two black 6 mm Phillips screws from the right side of the camera.
  9. Canon EOS Rebel XTi Back Casing Replacement: passo 9, immagine 1 di 3 Canon EOS Rebel XTi Back Casing Replacement: passo 9, immagine 2 di 3 Canon EOS Rebel XTi Back Casing Replacement: passo 9, immagine 3 di 3
    • Remove the two black 4 mm Phillips screws on each side of the camera under the strap hooks.
  10. Canon EOS Rebel XTi Back Casing Replacement: passo 10, immagine 1 di 1
    • Remove the two black 4 mm Phillips head screws on the side of the camera opposite to the hand grip.
  11. Canon EOS Rebel XTi Back Casing Replacement: passo 11, immagine 1 di 1
    • Remove the three 1 mm Phillips #0 screws located in the memory card slot.
    • Two of these screws are black, and the third is silver.
  12. Canon EOS Rebel XTi Back Casing Replacement: passo 12, immagine 1 di 1
    • Gently pry off the back casing.
    • Before completely removing the back casing, be sure to disconnect the single ribbon cable running from the motherboard to the LCD display.
    • Use a spudger to lift the tab on the ribbon cable's ZIF connector.
    • Gently pull the ribbon cable out of the connector.
Conclusione
Altre 4 persone hanno completato questa guida.
USF Tampa, Team 8-6, Eyestone Fall 2015 Membro di USF Tampa, Team 8-6, Eyestone Fall 2015
USFT-EYESTONE-F15S8G6
3 Membri
18 Guide realizzate
Un commento
This was invaluable - I had to replace the door over the memory card slot. I bought one through Amazon, but had no idea how to do it. Thankfully, this guide and my 64 bit driver kit (which I have used many, many times) made it a ten minute job. Thanks!
hoppergs - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 20
Tutti i Tempi: 2,211
