Salta al contenuto principale
Canon EOS Rebel XSi Mother Board Replacement
Cosa ti serve
  1. Canon EOS Rebel XSi Mother Board Replacement, Back Panel: passo 1, immagine 1 di 1
    • Squeeze the eyepiece between your index finger and thumb and lift up and off.
  2. Canon EOS Rebel XSi Mother Board Replacement: passo 2, immagine 1 di 1
    • Using the PH000 screwdriver head, remove the four 4 mm screws on the bottom of the camera.
  3. Canon EOS Rebel XSi Mother Board Replacement: passo 3, immagine 1 di 1
    • Using the PH000 screwdriver head, remove the two 3mm screws on the right side of the camera (from the LCD screen).
  4. Canon EOS Rebel XSi Mother Board Replacement: passo 4, immagine 1 di 1
    • Remove grip by slowly peeling off.
  5. Canon EOS Rebel XSi Mother Board Replacement: passo 5, immagine 1 di 1
    • Using the PH000 screwdriver, remove the four 4mm screws behind the eyepiece.
  6. Canon EOS Rebel XSi Mother Board Replacement: passo 6, immagine 1 di 1
    • Using the PH000 screwdriver head, remove one 4 mm screw on the left side of the camera (from the LCD screen).
  7. Canon EOS Rebel XSi Mother Board Replacement: passo 7, immagine 1 di 1
    • Remove the side panel by lifting off with fingers.
  8. Canon EOS Rebel XSi Mother Board Replacement: passo 8, immagine 1 di 1
    • Use hands to pry off the back panel.
  9. Canon EOS Rebel XSi Mother Board Replacement, Mother Board: passo 9, immagine 1 di 1
    • Using the PH00 screwdriver head, unscrew the three 3mm screws.
  10. Canon EOS Rebel XSi Mother Board Replacement: passo 10, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • Disconnect the five cables attached to the motherboard by gently pulling with tweezers.
  11. Canon EOS Rebel XSi Mother Board Replacement: passo 11, immagine 1 di 1
    • Remove tab from base by lifting up with finger.
  12. Canon EOS Rebel XSi Mother Board Replacement: passo 12, immagine 1 di 1
    • Using the PH00 screwdriver head, unscrew the three 3mm screws on the left side of the camera.
  13. Canon EOS Rebel XSi Mother Board Replacement: passo 13, immagine 1 di 1
    • Using the PH00 screwdriver head, unscrew the last 4mm screw from the motherboard.
  14. Canon EOS Rebel XSi Mother Board Replacement: passo 14, immagine 1 di 2 Canon EOS Rebel XSi Mother Board Replacement: passo 14, immagine 2 di 2
    • Remove motherboard by gently lifting out with fingers.
Conclusione
Altre 3 persone hanno completato questa guida.
Erik Mork
Membro da: 01/27/17
602 Reputazione
5 Guide realizzate
Cal Poly, Team 22-10, Maness Winter 2017 Membro di Cal Poly, Team 22-10, Maness Winter 2017
CPSU-MANESS-W17S22G10
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 36
Tutti i Tempi: 2,230
