Salta al contenuto principale
Canon EOS Rebel XSi Daughter Board Replacement
Cosa ti serve
  1. Canon EOS Rebel XSi Daughter Board Replacement, Back Panel: passo 1, immagine 1 di 1
    • Squeeze the eyepiece between your index finger and thumb and lift up and off.
  2. Canon EOS Rebel XSi Daughter Board Replacement: passo 2, immagine 1 di 1
    • Using the PH000 screwdriver head, remove the four 4 mm screws on the bottom of the camera.
  3. Canon EOS Rebel XSi Daughter Board Replacement: passo 3, immagine 1 di 1
    • Using the PH000 screwdriver head, remove the two 3mm screws on the right side of the camera (from the LCD screen).
  4. Canon EOS Rebel XSi Daughter Board Replacement: passo 4, immagine 1 di 1
    • Remove grip by slowly peeling off.
  5. Canon EOS Rebel XSi Daughter Board Replacement: passo 5, immagine 1 di 1
    • Using the PH000 screwdriver, remove the four 4mm screws behind the eyepiece.
  6. Canon EOS Rebel XSi Daughter Board Replacement: passo 6, immagine 1 di 1
    • Using the PH000 screwdriver head, remove one 4 mm screw on the left side of the camera (from the LCD screen).
  7. Canon EOS Rebel XSi Daughter Board Replacement: passo 7, immagine 1 di 1
    • Remove the side panel by lifting off with fingers.
  8. Canon EOS Rebel XSi Daughter Board Replacement: passo 8, immagine 1 di 1
    • Use hands to pry off the back panel.
  9. Canon EOS Rebel XSi Daughter Board Replacement, Front Panel: passo 9, immagine 1 di 1
    • Using the PH000 screwdriver head, remove the four 3mm screws on the front
  10. Canon EOS Rebel XSi Daughter Board Replacement: passo 10, immagine 1 di 1
    • Remove front grip by gently peeling from the edge towards the center of the camera
  11. Canon EOS Rebel XSi Daughter Board Replacement: passo 11, immagine 1 di 1
    • Using the PH000 screwdriver head, unscrew the 3 mm screw that was under the grip
  12. Canon EOS Rebel XSi Daughter Board Replacement: passo 12, immagine 1 di 1
    • Using the PH000 screwdriver, remove the 4mm screw at the bottom of the camera
  13. Canon EOS Rebel XSi Daughter Board Replacement: passo 13, immagine 1 di 3 Canon EOS Rebel XSi Daughter Board Replacement: passo 13, immagine 2 di 3 Canon EOS Rebel XSi Daughter Board Replacement: passo 13, immagine 3 di 3
    • Remove the front panel by using tweezers to pry the panel over the metal ring protrusion
  14. Canon EOS Rebel XSi Daughter Board Replacement, Daughter Board: passo 14, immagine 1 di 1
    • Using the PH000 screwdriver head, remove the three 3mm screws
  15. Canon EOS Rebel XSi Daughter Board Replacement: passo 15, immagine 1 di 1
    • Carefully remove the cable from its plastic base with fingers
  16. Canon EOS Rebel XSi Daughter Board Replacement: passo 16, immagine 1 di 1
    • Gently slide board out with thumb
  17. Canon EOS Rebel XSi Daughter Board Replacement: passo 17, immagine 1 di 1
    • Gently disconnect cable by pulling out from plastic base with fingers
  18. Canon EOS Rebel XSi Daughter Board Replacement: passo 18, immagine 1 di 1
    • Disconnect cables by pulling out from base with fingers
Conclusione
Altre 2 persone hanno completato questa guida.
Erik Mork
Membro da: 01/27/17
596 Reputazione
5 Guide realizzate
Cal Poly, Team 22-10, Maness Winter 2017 Membro di Cal Poly, Team 22-10, Maness Winter 2017
CPSU-MANESS-W17S22G10
4 Membri
10 Guide realizzate
Un commento
what does this fix
djratlif - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 10
Tutti i Tempi: 1,231
