Salta al contenuto principale
Canon EOS Rebel XS Strap Loops Replacement
Cosa ti serve
  1. Canon EOS Rebel XS Strap Loops Replacement, Latch Side Cover: passo 1, immagine 1 di 1
    • Remove the two 3mm (1/8") black screws from the side cover using a #00 Phillips screwdriver.
  2. Canon EOS Rebel XS Strap Loops Replacement: passo 2, immagine 1 di 1
    • On the bottom, remove the 6mm (13/64") screw with the #00 Phillips Screwdriver.
    • Pry up the panel; starting from the front/bottom corner, as indicated.
    • There's a concealed lip, under the opposite edge.
  3. Canon EOS Rebel XS Strap Loops Replacement, Disassembling Canon EOS Rebel XS Front Cover: passo 3, immagine 1 di 1
    • Remove three medium length screws from the bottom of the camera
  4. Canon EOS Rebel XS Strap Loops Replacement: passo 4, immagine 1 di 1
    • Remove the two medium length screws on the front panel of the camera above the lens mount.
    • Once you done, you may use the Spudger to panel from non-grip side.
    • If you start on the grip side, it will be more challenging to loosen the panel.
  5. Canon EOS Rebel XS Strap Loops Replacement, Back Cover: passo 5, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Remove the three long black screws from the bottom using a #00 Phillips screwdriver.
    • Use tweezers to lift the panel.
  6. Canon EOS Rebel XS Strap Loops Replacement: passo 6, immagine 1 di 1
    • Once you have detached the back cover, use a pair of tweezers to lightly pull on strap found connecting the back cover to the camera.
  7. Canon EOS Rebel XS Strap Loops Replacement, Grip: passo 7, immagine 1 di 1
    • Remove the two 4.5mm (.18in) long black screws from the camera grip using a #00 Phillips screwdriver.
  8. Canon EOS Rebel XS Strap Loops Replacement: passo 8, immagine 1 di 1
    • Use your fingertip to pry off the external shutter port cover.
  9. Canon EOS Rebel XS Strap Loops Replacement: passo 9, immagine 1 di 1
    • Remove the two 5mm (.20in) long silver screws securing the grip to the camera using a #00 Phillips screwdriver.
  10. Canon EOS Rebel XS Strap Loops Replacement: passo 10, immagine 1 di 3 Canon EOS Rebel XS Strap Loops Replacement: passo 10, immagine 2 di 3 Canon EOS Rebel XS Strap Loops Replacement: passo 10, immagine 3 di 3
    • Use the spudger tool to carefully pry the grip from the rest of the camera.
  11. Canon EOS Rebel XS Strap Loops Replacement: passo 11, immagine 1 di 1
    • Once the grip is loose, use your fingers to remove it from the camera.
  12. Canon EOS Rebel XS Strap Loops Replacement, Eyepiece: passo 12, immagine 1 di 2 Canon EOS Rebel XS Strap Loops Replacement, Eyepiece: passo 12, immagine 2 di 2
    • Grasp the eyepiece with your fingers and slide upwards to remove it.
  13. Canon EOS Rebel XS Strap Loops Replacement, Top Panel: passo 13, immagine 1 di 1
    Compra
    • Remove the following ribbons with the tweezers by gently pulling on them.
    • Remove the three black screws, near the eye piece, using the Phillips Screwdriver.
  14. Canon EOS Rebel XS Strap Loops Replacement: passo 14, immagine 1 di 1
    • Remove the cable heads attached on the front side of the camera next to the lens mount.
    • Be gentle when puling wires lose, use the tweezers to remove the wires.
  15. Canon EOS Rebel XS Strap Loops Replacement: passo 15, immagine 1 di 1
    • You can use your fingers to pull the top panel of the camera.
  16. Canon EOS Rebel XS Strap Loops Replacement, Strap Loops: passo 16, immagine 1 di 3 Canon EOS Rebel XS Strap Loops Replacement, Strap Loops: passo 16, immagine 2 di 3 Canon EOS Rebel XS Strap Loops Replacement, Strap Loops: passo 16, immagine 3 di 3
    • Remove the two 5.0mm (.20in) silver screws from the first loop hole using a #00 Phillips screwdriver (Picture Two).
    • Remove the 6.8mm (.27in) wide head silver screw from the second loop hole using a #00 Phillips screwdriver (Picture Three).
  17. Canon EOS Rebel XS Strap Loops Replacement: passo 17, immagine 1 di 2 Canon EOS Rebel XS Strap Loops Replacement: passo 17, immagine 2 di 2
    • Use your fingers to remove the loop holes.
Conclusione
Daniel Bussone
Membro da: 01/28/11
1.251 Reputazione
11 Guide realizzate
Cal Poly, Team 3-41, Regan Winter 2011 Membro di Cal Poly, Team 3-41, Regan Winter 2011
CPSU-REGAN-W11S3G41
2 Membri
21 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 10
Tutti i Tempi: 903
