Introduzione
Use this guide to replace the interior eyepiece of the camera.
Cosa ti serve
Remove the two 3mm (1/8") black screws from the side cover using a #00 Phillips screwdriver.
Remove three medium length screws from the bottom of the camera
Attrezzo utilizzato in questo passaggio:Tweezers$4.99
Remove the three long black screws from the bottom using a #00 Phillips screwdriver.
Use tweezers to lift the panel.
Remove the following ribbons with the tweezers by gently pulling on them.
Remove the three black screws, near the eye piece, using the Phillips Screwdriver.
After removing the top panel, you can use your fingers to remove the eye piece from the camera.
2Commenti sulla guida
How do you replace the internal battery?
