Salta al contenuto principale
Canon EOS Rebel XS 35mm Top Cover Replacement
Cosa ti serve
  1. Canon EOS Rebel XS 35mm Top Cover Replacement, Top Cover: passo 1, immagine 1 di 2 Canon EOS Rebel XS 35mm Top Cover Replacement, Top Cover: passo 1, immagine 2 di 2
    • Using a PH000 screwdriver bit, remove the three black screws shown in the two pictures that are all 4 mm in length and 1 mm in diameter.
  2. Canon EOS Rebel XS 35mm Top Cover Replacement: passo 2, immagine 1 di 1
    • Using a Phillips #000 screwdriver, remove the two black screws shown in the picture that are both 6 mm in length and 1.25 mm in diameter.
  3. Canon EOS Rebel XS 35mm Top Cover Replacement: passo 3, immagine 1 di 1
    • Pull off the front cover.
  4. Canon EOS Rebel XS 35mm Top Cover Replacement: passo 4, immagine 1 di 3 Canon EOS Rebel XS 35mm Top Cover Replacement: passo 4, immagine 2 di 3 Canon EOS Rebel XS 35mm Top Cover Replacement: passo 4, immagine 3 di 3
    • Using an opening tool (you can also use your nails, but try not to use something potentially damaging to the camera such as metal), separate the top cover from the rest of the camera!
Conclusione
christiansvezia
Membro da: 10/24/18
1.108 Reputazione
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 9
Tutti i Tempi: 323
