Salta al contenuto principale
Canon EOS Rebel XS 35mm Lens Mount Parts Replacement
Cosa ti serve
  1. Canon EOS Rebel XS 35mm Lens Mount Parts Replacement, Lens Mount Parts: passo 1, immagine 1 di 1
    • Using a PH000 screwdriver bit, remove the 2 black screws circled in the picture, which are both 6 mm in length and 1.25 mm in diameter.
  2. Canon EOS Rebel XS 35mm Lens Mount Parts Replacement: passo 2, immagine 1 di 1
    • Using a PH000 screwdriver bit, remove the 5 black screws circled in the picture, which are all 5.5 mm in length and 2 mm in diameter.
  3. Canon EOS Rebel XS 35mm Lens Mount Parts Replacement: passo 3, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Simply using your fingers - although you can use something else such as tweezers - remove the first layer of the lens mount. This first layer is black, plastic, has a red dot at the top, and so on.
  4. Canon EOS Rebel XS 35mm Lens Mount Parts Replacement: passo 4, immagine 1 di 1
    • Using (preferably) tweezers - although you can also use your fingers - remove the flimsy brass-colored layer of the lens mount.
  5. Canon EOS Rebel XS 35mm Lens Mount Parts Replacement: passo 5, immagine 1 di 1
    • Using (preferably) tweezers - although you can also use your fingers - remove the silver layer of the lens mount.
Conclusione
Reassembly can be a lot harder than disassembly for this part of the camera, which accounts for the large range in estimated time.
christiansvezia
Membro da: 10/24/18
1.108 Reputazione
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 17
Tutti i Tempi: 413
