Salta al contenuto principale
Canon EOS Rebel XS 35mm Flash Replacement
Cosa ti serve
  1. Canon EOS Rebel XS 35mm Flash Replacement, Flash: passo 1, immagine 1 di 2 Canon EOS Rebel XS 35mm Flash Replacement, Flash: passo 1, immagine 2 di 2
    • Pull up on the flash / the camera part housing the flash, as shown in the pictures. If this isn't working, try these things not shown in the pictures: 1) using a spudger, your nail, or the like to pry it open; or 2) pull it open with your finger and thumb on either side of it.
  2. Canon EOS Rebel XS 35mm Flash Replacement: passo 2, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Phillips #000 Screwdriver
    $5.49
    Compra
    • Using a PH000 screwdriver bit, remove the two silver screws circled in the picture. Both screws are 5 mm in length and about 1.25 mm in diameter.
Conclusione
christiansvezia
Membro da: 10/24/18
1.108 Reputazione
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 526
