Salta al contenuto principale
Canon EOS Rebel XS 35mm Camera Mode Dial Replacement
Cosa ti serve
  1. Canon EOS Rebel XS 35mm Camera Mode Dial Replacement, Top Cover: passo 1, immagine 1 di 2 Canon EOS Rebel XS 35mm Camera Mode Dial Replacement, Top Cover: passo 1, immagine 2 di 2
    • Using a PH000 screwdriver bit, remove the three black screws shown in the two pictures that are all 4 mm in length and 1 mm in diameter.
  2. Canon EOS Rebel XS 35mm Camera Mode Dial Replacement: passo 2, immagine 1 di 1
    • Using a Phillips #000 screwdriver, remove the two black screws shown in the picture that are both 6 mm in length and 1.25 mm in diameter.
  3. Canon EOS Rebel XS 35mm Camera Mode Dial Replacement: passo 3, immagine 1 di 1
    • Pull off the front cover.
  4. Canon EOS Rebel XS 35mm Camera Mode Dial Replacement: passo 4, immagine 1 di 3 Canon EOS Rebel XS 35mm Camera Mode Dial Replacement: passo 4, immagine 2 di 3 Canon EOS Rebel XS 35mm Camera Mode Dial Replacement: passo 4, immagine 3 di 3
    • Using an opening tool (you can also use your nails, but try not to use something potentially damaging to the camera such as metal), separate the top cover from the rest of the camera!
  5. Canon EOS Rebel XS 35mm Camera Mode Dial Replacement, Camera Mode Dial: passo 5, immagine 1 di 1
    • Locate the camera dial (surrounded by a red square) and turn the top cover of the camera upside down for access to the screw underneath the dial.
  6. Canon EOS Rebel XS 35mm Camera Mode Dial Replacement: passo 6, immagine 1 di 1
    • Using a PH000 screwdriver bit, remove the silver screw circled in the picture, which is 3 mm in length and 1 mm in diameter.
  7. Canon EOS Rebel XS 35mm Camera Mode Dial Replacement: passo 7, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • Using tweezers, remove the metal part surrounded by the red square.
  8. Canon EOS Rebel XS 35mm Camera Mode Dial Replacement: passo 8, immagine 1 di 1
    • Using your fingers, remove the black dial! (The dial is surrounded by a red square in the picture.)
Conclusione
christiansvezia
Membro da: 10/24/18
1.136 Reputazione
10 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 15
Ultimi 30 Giorni: 60
Tutti i Tempi: 2,549
