Salta al contenuto principale
Canon EOS Rebel XS 35mm Bottom Cover and More Replacement
Cosa ti serve
  1. Canon EOS Rebel XS 35mm Bottom Cover and More Replacement, Bottom Cover: passo 1, immagine 1 di 1
    • Remove 6 screws using a PH000 Screwdriver.
    • Remove 1 (7mm) screw
    • Remove 5 (4mm) screws
  2. Canon EOS Rebel XS 35mm Bottom Cover and More Replacement: passo 2, immagine 1 di 1
    • With your fingers, push on the bottom cover with a horizontal force until it clicks and separates.
  3. Canon EOS Rebel XS 35mm Bottom Cover and More Replacement: passo 3, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • With tweezers - although you can also use your fingers - you may remove these 5 gears and place them somewhere else for the time being. They fall out easily while you're working, so this will help you stay organized.
  4. Canon EOS Rebel XS 35mm Bottom Cover and More Replacement, Bottom Cover and More: passo 4, immagine 1 di 1
    • Remove the 5mm silver Phillips #000 screw.
    • Remove three 4mm Phillips #000 screws.
  5. Canon EOS Rebel XS 35mm Bottom Cover and More Replacement: passo 5, immagine 1 di 1
    • Remove the silver plate with tweezers or fingers.
  6. Canon EOS Rebel XS 35mm Bottom Cover and More Replacement: passo 6, immagine 1 di 1
    • Be mindful of the spring attached to the plastic piece. Do not lose it.
    • Remove the plastic black part.
  7. Canon EOS Rebel XS 35mm Bottom Cover and More Replacement: passo 7, immagine 1 di 1
    • Remove the black gear with tweezers or fingers.
  8. Canon EOS Rebel XS 35mm Bottom Cover and More Replacement: passo 8, immagine 1 di 1
    • Remove the gear with tweezers or fingers.
  9. Canon EOS Rebel XS 35mm Bottom Cover and More Replacement: passo 9, immagine 1 di 1
    • Remove the part indicated in the picture with tweezers or fingers.
  10. Canon EOS Rebel XS 35mm Bottom Cover and More Replacement: passo 10, immagine 1 di 1
  11. Canon EOS Rebel XS 35mm Bottom Cover and More Replacement: passo 11, immagine 1 di 1
  12. Canon EOS Rebel XS 35mm Bottom Cover and More Replacement: passo 12, immagine 1 di 2 Canon EOS Rebel XS 35mm Bottom Cover and More Replacement: passo 12, immagine 2 di 2
    • Remove two 3mm Phillips #000 screws.
    • Remove two silver 3.5mm Phillips #000 screws.
  13. Canon EOS Rebel XS 35mm Bottom Cover and More Replacement: passo 13, immagine 1 di 1
    • Remove the second silver plate using tweezers or fingers.
Conclusione
christiansvezia
Membro da: 10/24/18
1.136 Reputazione
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 15
Ultimi 30 Giorni: 23
Tutti i Tempi: 457
