Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Store
Introduzione
Going on a long trip, and need to take extra memory? This guide will show you how to remove and switch out your SD card.
Strumenti
Parti
Nessuna parte specificata.
  1. Lay the camera on its back so that the card/battery door is facing you.
    • Lay the camera on its back so that the card/battery door is facing you.
    • Using your fingernail, slide the tab on the battery door up to release the battery door latch.
  2. Lift the now free card/battery door to reveal the battery compartment.
    • Lift the now free card/battery door to reveal the battery compartment.
    • Push the gray lever to the right side so that the battery can be removed and replaced with a new one.
  3. Lay the camera on its back so that the card/battery door is facing you.
  4. Open the battery compartment by lifting the card/battery door. You will see a thin SD Card slot below the battery.
    • Open the battery compartment by lifting the card/battery door. You will see a thin SD Card slot below the battery.
    • Push in the old SD card until it clicks to remove it and then push in the new card until it clicks into place.
Conclusione
Altre 3 persone hanno completato questa guida.
Austin Tucker
Membro da: 27/08/2015
994 Reputazione
4 Guide realizzate
USF Tampa, Team 16-4, Wollert Fall 2015 Membro di USF Tampa, Team 16-4, Wollert Fall 2015
USFT-WOLLERT-F15S16G4
4 Membri
14 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 21
Tutti i Tempi: 1,870
