Salta al contenuto principale
Introduzione
This guide details how to replace the flash bulb of this camera.
  1. Locate the battery cover at the bottom of the camera.
    • Locate the battery cover at the bottom of the camera.
    • Pull down on the black tab to open the cover.
  2. Push the grey tab on the right side of the battery.
    • Push the grey tab on the right side of the battery.
    • Remove the battery from the slot.
  3. Kits di riparazione iPhone X
    Garanzia finita? Non preoccuparti, abbiamo la soluzione.
    Acquista ora
    Acquista ora
  4. Using the Phillips screwdriver, unscrew the two 4.9mm Phillips head screws which are located underneath the flash.
    • Using the Phillips screwdriver, unscrew the two 4.9mm Phillips head screws which are located underneath the flash.
  5. Remove the covering.
    • Remove the covering.
  6. Use the tweezers to remove the excess glue around the wiring. This will allow you to cut the wire and remove the light in the next step.
    • Use the tweezers to remove the excess glue around the wiring. This will allow you to cut the wire and remove the light in the next step.
  7. Use the wire cutters to cut the wiring connected to the flash.
    • Use the wire cutters to cut the wiring connected to the flash.
Conclusione
Altre 6 persone hanno completato questa guida.
Jordan Rabold
Membro da: 14/04/2014
699 Reputazione
3 Guide realizzate
Cal Poly, Team 12-33, Maness Spring 2014 Membro di Cal Poly, Team 12-33, Maness Spring 2014
CPSU-MANESS-S14S12G33
4 Membri
7 Guide realizzate
how do you reverse step 6 - cutting the wires?
jeremyyoung - Replica
You dont tell how to make sure capacitors are discharged before changing the flash ? and do you know what is the replacement number of the flash bulb itself ?
jackqc09 - Replica
No parts required? So I can repair my flash not having to buy a new bulb? haha Please, I need the link from where I repair my burned built-in flash :/
gustavoaleme - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 31
Tutti i Tempi: 3,025
