Introduzione
The knobs, switches, buttons, flash and other components are part of a single assembly from Canon. Canon do not generally sell parts directly to consumers, and suggest you send your camera to them for repairs.
This guide will show you how to remove the top, front and back panels of your camera, so you can access and replace many of the external components that may have become worn or broken.
Cosa ti serve
As you can see here, we've got a damaged hot shoe on this T2i (550D). A little bit of searching on eBay has yielded the part we need to replace. It's an entire assembly of the top cover.
You'll need the following:
Plastic opening tool
Small Screwdrivers
Pliers (or surgical clamps :D)
Pen and paper
Get the camera ready by removing the neck strap, battery, lens and SD card.
Remove two screws from the right side of the camera, next to the CF card.
Remove one screw from the right side of the camera. Leave those under the rubber door for later, we just want to do the one outside for now.
Remove the eyepiece, and the two screws beneath it.
Remove the two black screws on the front of the camera, just above the lens mount.
Remove the screw in the centre of the viewfinder focus knob. It will come out with the knob attached.
Pry open the bottom of the camera with the opening tool or screwdriver. The front panel should come forward, but must be lifted (pried) over the tripod mounting. It may help to slide a small screwdriver under the panel via the battery door.
Once you've slipped the front cover's base over the tripod mount, gently pull it away from the camera body.
Locate the ribbon connector connecting the main circuit board to the top cover, near "zoom in" button, under where your right thumb would sit while using the camera.
Carefully and gently pry the connector lose with the blade of a plastic opening tool.
Locate the microphone connection, and disconnect it. It is to the left of the sensor on the circuit board.
On the front of the camera, disconnect the red and yellow wires from the circuit board. If you have a plastic tweezers, simply pull them away from their connectors.
The top cover is now free. Gently pull it away from the body, and replace it with the new one. Be sure that the cables are running to the correct side of the body. Red and rellow to the front; ribbon and tiny black and red microphone cable to the back.
As you seat the cover, note that there are 5 cables dangling from the new part.
A pair of wires with a red connector and dark wire.
A pair of wires with a yellow connector, one yellow, one white.
A tiny red and black wire with a white connector.
A gold ribbon cable with flat square connector.
In my case, I did not notice the black wire until I removed it. I believe it is the ground wire for hot shoe devices. It slots into a tiny space on the top of the camera, in front of the circuit board.
Bend the wire to match the old one, as mine was straight and difficult to manage.
Use a tweezers to slide the wire into the white connector slot on the board.
Altre 3 persone hanno completato questa guida.
5 Commenti
I presume you mean the ribbon cable. If I recall, it just smushed on there. The pins are very small as is the plastic, so there may not be much of a "snap" as it goes into place. No solder required. Be firm but gentle.
Thanks for this nice tutorial!
I have however three comments:
- Removing the front cover in step 4 can be tedious because of tripod mount. It is easier to remove the 2 screws in the connector compartment (Step 5) before, so that back cover/LCD can be partially removed (no need to fully remove it) to better deal with tripod mount...
- When removing the back cover/LCD it is probably safer to remove the flex from mother board connector before fully removing back cover (end of step 5). It is easy since flex connector lever is oriented such that you can open it from the bottom. In any case DO NOT fold that flex as shown on step 6 pictures, you might seriouly damage this VERY fragile flex (guess how I know that).
- About, the mystery black wire in step 8, it is related to flash "feedback" system. Most certainly a small piece of optical fiber, that feeds back some light from the flash to a light sensor on the mother board (the white "connector"). If you forget to put it back, the flash will alway fire at full power!
