Salta al contenuto principale
Canon EOS Rebel T2i Hot Shoe Replacement
Cosa ti serve
  1. Canon EOS Rebel T2i Hot Shoe Replacement, Hot Shoe: passo 1, immagine 1 di 3 Canon EOS Rebel T2i Hot Shoe Replacement, Hot Shoe: passo 1, immagine 2 di 3 Canon EOS Rebel T2i Hot Shoe Replacement, Hot Shoe: passo 1, immagine 3 di 3
    • Using the flat end of the spudger, carefully pry the rear part of the hot shoe baseplate upward.
    • Pull the spudger backwards to remove the base plate.
    • Removing this plate reveals the mounting screws for the hot shoe.
  2. Canon EOS Rebel T2i Hot Shoe Replacement: passo 2, immagine 1 di 1
    • To remove the hot shoe, unscrew the following mounting screws holding it in place:
    • Four M2.5x3.8mm JIS #000 screws
  3. Canon EOS Rebel T2i Hot Shoe Replacement: passo 3, immagine 1 di 1
    • With the screws removed, the hot shoe can now be lifted out of place.
Conclusione
To reassemble your device, follow these instructions in reverse order. When tightening screws that hold the hot shoe in place, be very careful to not scratch the rail of the hot shoe. If the rail of the hot shoe has any scratches or dents, it can be more difficult to mount the external flash.
Altre 2 persone hanno completato questa guida.
Documenti Allegati
Un commento
My hot shoe actually came off. I have ordered various sizes of screws to replace it but none work. I need a new hot shoe and screws. What size screws do I need with a canon rebel T2i camera?
Cindy Mitchum - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 33
Tutti i Tempi: 5,910
