Salta al contenuto principale
Canon EOS Rebel T2i Clock Battery Replacement
Cosa ti serve
  1. Canon EOS Rebel T2i Clock Battery Replacement, Clock Battery: passo 1, immagine 1 di 2 Canon EOS Rebel T2i Clock Battery Replacement, Clock Battery: passo 1, immagine 2 di 2
    • This is not reversible and your camera will look like this forever after snapping off the plastic clip.
    • Unfortunately I don't have a before picture, but the battery is under a plastic cover that you have to snap off.
    • I did not take the 2nd picture, but it is an example of what it looks like here before breaking the plastic. Source:
    • Replacing internal backup battery of Canon EOS Rebel T3i camera
  2. Canon EOS Rebel T2i Clock Battery Replacement: passo 2, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • Can use thin flat-head screwdriver or tweezers to pry off the cover and reveal the battery slot.
  3. Canon EOS Rebel T2i Clock Battery Replacement: passo 3, immagine 1 di 2 Canon EOS Rebel T2i Clock Battery Replacement: passo 3, immagine 2 di 2
    • Can now see the battery and any model numbers on it. On my camera it is labeled "MS614SE"
    • Use a thin flat-head screwdriver or your tweezers to get the old battery out.
    • Slide in the new one and push it in with your finger.
Linea Traguardo
Altre 3 persone hanno completato questa guida.
Un commento
Hi, Great help!
Where can I buy the replacement MS614SE?
Kam
Kam Lam - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 81
Tutti i Tempi: 2,488
