Salta al contenuto principale
Canon EOS Rebel T1i Front Screen Replacement
Cosa ti serve
  1. Canon EOS Rebel T1i Front Screen Replacement, Front Screen: passo 1, immagine 1 di 1
    • Clean the broken or cracked screen as best as possible.
    • Place the suction cup on the damaged screen.
  2. Canon EOS Rebel T1i Front Screen Replacement: passo 2, immagine 1 di 2 Canon EOS Rebel T1i Front Screen Replacement: passo 2, immagine 2 di 2
    • While holding the suction cup flat against the camera screen, suction the two together by pinching the orange handles to meet at the center.
  3. Canon EOS Rebel T1i Front Screen Replacement: passo 3, immagine 1 di 3 Canon EOS Rebel T1i Front Screen Replacement: passo 3, immagine 2 di 3 Canon EOS Rebel T1i Front Screen Replacement: passo 3, immagine 3 di 3
    • Grab the handle of the suction cup and gently lift it up at an angle, as demonstrated in the picture.
    • Remove the plastic screen from the camera.
    • Release the broken screen by pulling down the lever of the suction cup.
Conclusione
Altre 5 persone hanno completato questa guida.
Michael Peck
Membro da: 04/14/14
167 Reputazione
1 Guida realizzata
Cal Poly, Team 3-41, Maness Spring 2014 Membro di Cal Poly, Team 3-41, Maness Spring 2014
CPSU-MANESS-S14S3G41
4 Membri
10 Guide realizzate
Un commento
Be sure to measure the size of your screen before buying the suction cups. I got the heavy-duty ones and then found that they were too big for my Rebel T1i screen.
cmorris - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 27
Tutti i Tempi: 5,469
