Salta al contenuto principale
Canon EOS Rebel G Viewfinder Replacement
Cosa ti serve
  1. Canon EOS Rebel G Viewfinder Replacement, Front Panel: passo 1, immagine 1 di 1
    • Using a #00 Phillips screw driver, remove three 4.4 mm Phillips screws as indicated by the red circles.
  2. Canon EOS Rebel G Viewfinder Replacement: passo 2, immagine 1 di 2 Canon EOS Rebel G Viewfinder Replacement: passo 2, immagine 2 di 2
    • Using your finger, peel back the textured grip so the components are separated.
  3. Canon EOS Rebel G Viewfinder Replacement: passo 3, immagine 1 di 3 Canon EOS Rebel G Viewfinder Replacement: passo 3, immagine 2 di 3 Canon EOS Rebel G Viewfinder Replacement: passo 3, immagine 3 di 3
    • Using the flat end of a spudger, loosen the connection between the front panel and the device.
    • Remove the front panel using your hands.
  4. Canon EOS Rebel G Viewfinder Replacement, Top Panel: passo 4, immagine 1 di 1
    • Turn Camera over.
    • Using a #00 Phillips screw driver, unscrew the two 4.9 mm Phillips screws located on either side of the viewfinder.
  5. Canon EOS Rebel G Viewfinder Replacement: passo 5, immagine 1 di 1
    • Using a #00 Phillips screw driver, unscrew the one 5.7 mm Phillips screw located next to the LCD screen.
  6. Canon EOS Rebel G Viewfinder Replacement: passo 6, immagine 1 di 1
    • Lay the camera on its back.
    • Unsolder the flash connection from the motherboard as noted by the blue circle.
  7. Canon EOS Rebel G Viewfinder Replacement: passo 7, immagine 1 di 3 Canon EOS Rebel G Viewfinder Replacement: passo 7, immagine 2 di 3 Canon EOS Rebel G Viewfinder Replacement: passo 7, immagine 3 di 3
    • Remove the top panel by lifting it from the back, pushing it forward over the camera and letting it rotate down in front of the camera.
  8. Canon EOS Rebel G Viewfinder Replacement, Viewfinder: passo 8, immagine 1 di 1
    • Unscrew the screws on either side of the viewfinder until the viewfinder can be lifted off
    • Two 8.5 mm Phillips screws
Conclusione
Kyle Reis
Membro da: 04/02/12
52 Reputazione
4 Guide realizzate
Cal Poly, Team 14-9, Forte Spring 2012 Membro di Cal Poly, Team 14-9, Forte Spring 2012
CPSU-FORTE-S12S14G9
5 Membri
36 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 15
Tutti i Tempi: 2,997
