Introduzione
This guide shows you how to install the anchors for the camera strap.
Using a #00 Phillips screw driver, remove three 4.4 mm Phillips screws as indicated by the red circles.
  • Using a #00 Phillips screw driver, remove three 4.4 mm Phillips screws as indicated by the red circles.
Aggiungi Commento
Using your finger, peel back the textured grip so the components are separated.
  • Using your finger, peel back the textured grip so the components are separated.
Aggiungi Commento
  • Using the flat end of a spudger, loosen the connection between the front panel and the device.
  • Remove the front panel using your hands.
Aggiungi Commento
  • Turn Camera over.
  • Using a #00 Phillips screw driver, unscrew the two 4.9 mm Phillips screws located on either side of the viewfinder.
Aggiungi Commento
  • Using a #00 Phillips screw driver, unscrew the one 5.7 mm Phillips screw located next to the LCD screen.
Aggiungi Commento
  • Lay the camera on its back.
  • Unsolder the flash connection from the motherboard as noted by the blue circle.
Aggiungi Commento
  • Remove the top panel by lifting it from the back, pushing it forward over the camera and letting it rotate down in front of the camera.
Aggiungi Commento
  • Unscrew the 6.8 Phillips screw that holds the strap anchor by the LCD.
Aggiungi Commento
  • Unscrew the screws that hold the remaining strap anchor.
    • Two 4.9 mm Phillips screws
Aggiungi Commento
Conclusione
Kyle Reis
Membro da: 02/04/2012
49 Reputazione
4 Guide realizzate
Cal Poly, Team 14-9, Forte Spring 2012 Membro di Cal Poly, Team 14-9, Forte Spring 2012
CPSU-FORTE-S12S14G9
5 Membri
12 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,025
