Salta al contenuto principale
Canon EOS Rebel G Grip Replacement
Cosa ti serve
  1. Canon EOS Rebel G Grip Replacement, Front Panel: passo 1, immagine 1 di 1
    • Using a #00 Phillips screw driver, remove three 4.4 mm Phillips screws as indicated by the red circles.
  2. Canon EOS Rebel G Grip Replacement: passo 2, immagine 1 di 2 Canon EOS Rebel G Grip Replacement: passo 2, immagine 2 di 2
    • Using your finger, peel back the textured grip so the components are separated.
  3. Canon EOS Rebel G Grip Replacement: passo 3, immagine 1 di 3 Canon EOS Rebel G Grip Replacement: passo 3, immagine 2 di 3 Canon EOS Rebel G Grip Replacement: passo 3, immagine 3 di 3
    • Using the flat end of a spudger, loosen the connection between the front panel and the device.
    • Remove the front panel using your hands.
  4. Canon EOS Rebel G Grip Replacement, Grip: passo 4, immagine 1 di 1
    • Using a 00 Phillips screw driver, unscrew the two 4.9 mm Phillips screws. on the inside of the camera.
  5. Canon EOS Rebel G Grip Replacement: passo 5, immagine 1 di 1
    • Using a 00 Phillips screw driver, unscrew the two 4.3 mm Phillips screws on the side of the camera.
    • Use your fingers to pull out the plug that is located between the screw holes.
  6. Canon EOS Rebel G Grip Replacement: passo 6, immagine 1 di 2 Canon EOS Rebel G Grip Replacement: passo 6, immagine 2 di 2
    • Use the flat end of a spudger to pop the grip off and remove grip.
Conclusione
Kyle Reis
Membro da: 04/02/12
52 Reputazione
4 Guide realizzate
Cal Poly, Team 14-9, Forte Spring 2012 Membro di Cal Poly, Team 14-9, Forte Spring 2012
CPSU-FORTE-S12S14G9
5 Membri
36 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 12
Tutti i Tempi: 1,589
