Salta al contenuto principale
Canon EOS Digital Rebel (300D) Front Casing Replacement
Cosa ti serve
  1. Canon EOS Digital Rebel (300D) Front Casing Replacement, Remove the front screws: passo 1, immagine 1 di 1
    • Remove the two 7mm philips screws from the front casing.
  2. Canon EOS Digital Rebel (300D) Front Casing Replacement, Remove bottom screws: passo 2, immagine 1 di 1
    • Remove the three 1/8" philips screws from the bottom.
    • Remove the single 3/16" philips screw from the bottom.
  3. Canon EOS Digital Rebel (300D) Front Casing Replacement, Remove the right side screws: passo 3, immagine 1 di 1
    • Remove the two 1/8" philip screws from the right side of the front casing.
  4. Canon EOS Digital Rebel (300D) Front Casing Replacement, Remove battery door: passo 4, immagine 1 di 2 Canon EOS Digital Rebel (300D) Front Casing Replacement, Remove battery door: passo 4, immagine 2 di 2
    • Locate the lock of the battery door and pull it for allowing the door to be removed.
    • Remove the battery door.
  5. Canon EOS Digital Rebel (300D) Front Casing Replacement, Remove the battery door hinge mount: passo 5, immagine 1 di 1
    • Remove the two 1/8" philips screws from the hinge mount.
    • Take out the door hinge mount.
  6. Canon EOS Digital Rebel (300D) Front Casing Replacement, Remove internal screws: passo 6, immagine 1 di 2 Canon EOS Digital Rebel (300D) Front Casing Replacement, Remove internal screws: passo 6, immagine 2 di 2
    • Remove the screw holding the black cap which covers access holes to the screws holding the front casing to the battery compartment.
    • Remove the black cap pulling it to the right.
    • Remove the two 3/16" philips screws.
Conclusione
Claudio Felix
Membro da: 01/01/16
863 Reputazione
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 11
Tutti i Tempi: 1,064
