Introduzione
This guide shows you how to replace the top cover of the camera. This is also useful if you are trying to repair or replace a particular part located on the top cover, or are trying to gain access to a different component further inside the camera.
Note that the Phillips #000 screwdriver is marked as an optional tool as you can always use the JIS #000 screwdriver in its place (JIS screwdrivers won't damage Phillips head screws).
Cosa ti serve
Before beginning, remove the battery and SD card from the camera.
Using your thumbs, push up on the eyepiece to remove it.
Remove the battery door.
Open the battery door to about a 35° angle.
Pull the battery door straight outwards.
Using the plastic spudger tool, peel back the rubber grip on the right side of the camera to expose the screws.
Remove the following screws underneath the right rubber grip:
One M1.7x3.0mm JIS #000 screw
One M1.7x3.5mm JIS #000 screw
On the back of the camera, remove the following screws:
Two M1.7x5.5mm JIS #000 screws
On the bottom of the camera, remove the following screws:
Three M1.7x3.0mm JIS #000 screws
Slightly lift up the back cover from the camera, using a plastic spudger or opening tool as needed.
You can lift the back cover towards the bottom of the camera to get better access to remove the cables.
With a plastic spudger tool, gently lift up on the black locking tab on the ribbon cable connector.
Once the locking tab is lifted up, you can carefully pull out the ribbon cable.
Use the plastic spudger to gently pry off the other cable connecting the back cover to the camera.
With both of the cables disconnected, you can finish lifting off the back cover from the camera.
Peel the right rubber grip off the rest of the way.
On the front of the camera, remove the following screws:
Two M1.7x5.0mm Phillips #000 screws
One M1.7x4.5mm Phillips #000 screw
Two M1.7x6.0mm JIS #000 screws
On the right side of the camera, remove the following screws:
On the top of the camera, remove the following screw:
One M1.7x5.0mm Phillips #000 screw
On the underside of the top cover, remove the following screws:
On the back of the camera, remove the diopter adjusting dial.
Disconnect the microphone cable from the main PCB board.
Position a flathead 2.5mm screwdriver between the main PCB board connector and the microphone connector.
Gently wiggle the flathead screwdriver back and forth until the microphone connector comes free.
Using the plastic spudger tool, carefully pry up the ribbon cable connected to the top cover.
Gently disconnect the fiber optic cable from the main PCB board.
Use a pair of tweezers to grab the plastic tab on the optic cable and pull it out to the left.
Move the fiber optics cable and microphone cable away from the camera body so that it doesn't get caught while removing the top cover.
