Salta al contenuto principale
Canon EOS 70D Interface Cover Replacement
Cosa ti serve
  1. Canon EOS 70D Interface Cover Replacement, Interface Cover: passo 1, immagine 1 di 2 Canon EOS 70D Interface Cover Replacement, Interface Cover: passo 1, immagine 2 di 2
    • Before beginning, remove the battery and SD card from the camera.
    • Using your thumbs, push up on the eyepiece to remove it.
    • Remove the battery door.
    • Open the battery door to about a 35° angle.
    • Pull the battery door straight outwards.
  2. Canon EOS 70D Interface Cover Replacement: passo 2, immagine 1 di 3 Canon EOS 70D Interface Cover Replacement: passo 2, immagine 2 di 3 Canon EOS 70D Interface Cover Replacement: passo 2, immagine 3 di 3
    • Using a plastic spudger tool, peel off the rubber grip on the left side of the camera.
    • Underneath where the rubber grip was, remove the following screws:
    • Three M1.7x5.5mm Phillips #000 screws
    • Pry off the plastic interface cover.
    • Use a plastic opening tool if a fingernail doesn't work.
Conclusione
Documenti Allegati
Zephosk
Membro da: 09/26/24
5.457 Reputazione
34 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 13
Tutti i Tempi: 84
