Salta al contenuto principale
Canon EOS 60D: Replacing Eye piece and Battery door
  1. Canon EOS 60D: Replacing Eye piece and Battery door, Eye piece and Battery door: passo 1, immagine 1 di 2 Canon EOS 60D: Replacing Eye piece and Battery door, Eye piece and Battery door: passo 1, immagine 2 di 2
    • Removing the eyepiece is easy. There are two methods, you can do it yourself, or put it in your camera bag a dozen times and at least once, it will fall off.
    • Grip the eyepiece by the sides firmly (index finger and thumb). Wiggle it upwards until it is off.
  2. Canon EOS 60D: Replacing Eye piece and Battery door: passo 2, immagine 1 di 2 Canon EOS 60D: Replacing Eye piece and Battery door: passo 2, immagine 2 di 2
    • Open the battery door
    • Rotate the door so the one side of the hinge pops out (see photo #2)
    • Slide other pin out (it pops out the same, but this is easier)
Conclusione
Rubber grips will require adhesive. (I havent gotten this far, I assume rubber cement / double stick tape may work)
Altre 4 persone hanno completato questa guida.
Eric D
Membro da: 11/13/12
1.284 Reputazione
5 Guide realizzate
Un commento
But how do you REPLACE the rubber eye piece? Mine seems to be NOT glued, but in a tract of sorts.
Wendell C Durnil - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 17
Tutti i Tempi: 5,924
