Salta al contenuto principale
Canon EOS 60D Rear LCD Screen Replacement
Cosa ti serve
  1. Canon EOS 60D Rear LCD Screen Replacement, Rear LCD Screen Dissasembly: passo 1, immagine 1 di 1
    • Take the LCD out of its place to expose the Phillips #PH00 screws.
    • Remove the two 2.5 mm Phillips #PH00 black screws on both sides of the LCD screen.
    • Next remove the two 3 mm Phillips #PH00 black screws near both sides of the base where the screen swivels.
  2. Canon EOS 60D Rear LCD Screen Replacement: passo 2, immagine 1 di 1
    • Using a plastic opening tool, carefully pry off the back cover of the LCD.
  3. Canon EOS 60D Rear LCD Screen Replacement: passo 3, immagine 1 di 2 Canon EOS 60D Rear LCD Screen Replacement: passo 3, immagine 2 di 2
    • Remove the 3 mm Phillips #PH00 silver screw on the side of the screen.
    • Turn the screen to remove the second 3 mm Phillips #PH00 silver screw.
  4. Canon EOS 60D Rear LCD Screen Replacement: passo 4, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • Using the tweezers, carefully disconnect the rear connector by pulling it away from the screen.
  5. Canon EOS 60D Rear LCD Screen Replacement, Rear LCD Screen: passo 5, immagine 1 di 2 Canon EOS 60D Rear LCD Screen Replacement, Rear LCD Screen: passo 5, immagine 2 di 2
    • Remove the two 2.5 mm Phillips #PH00 silver screws using the PH00 screwdriver.
    • Using the plastic Spudger opening tool, carefully lift up on the medal tabs next to where the screws were located.
  6. Canon EOS 60D Rear LCD Screen Replacement: passo 6, immagine 1 di 1
    • Finally, remove the LCD screen by grabbing the clear plastic tab and lifting it carefully.
Conclusione
Altre 4 persone hanno completato questa guida.
USF Tampa, Team 16-6, Wollert Fall 2015 Membro di USF Tampa, Team 16-6, Wollert Fall 2015
USFT-WOLLERT-F15S16G6
3 Membri
14 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 57
Tutti i Tempi: 8,678
