Introduzione
This guide will help you replace the motherboard of your camera.
Be sure to use a magnetic mat or container to hold small screws. Keeping your screws organized will help you return them to their designated holes during reassembly.
Cosa ti serve
Take the LCD out of its place to expose the Phillips #PH00 screws.
Remove the two 2.5 mm Phillips #PH00 black screws on both sides of the LCD screen.
Next remove the two 3 mm Phillips #PH00 black screws near both sides of the base where the screen swivels.
Using a plastic opening tool, carefully pry off the back cover of the LCD.
Now, four 2.2 mm Phillips #PH00 screws holding a cover around the hinge should be visible.
Turn the swivel around to expose the remaining of the aforementioned screws.
Then use the PH00 screw driver to remove them.
Using the plastic opening tool, carefully pull up the rubber grip around the port side of the camera.
Remove the four different sized screws located beneath the rubber grip.
6 mm Phillips #PH00 screw.
3.4 mm Phillips #PH00 screw.
3.9 mm Phillips #PH00 screw.
2.2 mm Phillips #PH00 screw.
Carefully pry off the LCD screen connector up from the motherboard to disconnect it, using the plastic opening tool.
Remove the two 2.8 mm Phillips #PH00 black screws on the back of the swivel assembly using the PH00 screwdriver.
If the display cable is glued in place, carefully lift it off taking care with the flex cable underneath.
Remove the two 4.4 mm Phillips #PH00 screws holding the silver cover using the PH00 screwdriver.
Next lift the cover off of the motherboard.
Next the wires are able to come off.
The RED arrows indicate a small hinge locking the wire in. To remove the wire, follow the same steps taken to remove the wire in the prior steps.
The ORANGE markers indicate that you need to lift the wire up and off of the motherboard. Using the opening tool, follow the same steps used to remove the swivel screen wire.
Next it is recommended that you use tweezers to carefully remove all hinged wires as demonstrated by the YELLOW arrow on the second image in this step.
With the motherboard lifted, remove the indicated wire by using a plastic opening tool.
With the first bottom wire removed, the motherboard can be lifted higher, showing two more hidden wires.
Remove the wire indicated by the ORANGE arrow by undoing a hinge and sliding the wire out.
Remove the wire indicated by the YELLOW arrow by gently pulling it straight out of the socket it is seated in.
Altre 14 persone hanno completato questa guida.
3 Commenti
Dear Tyler, there is no need to remove the lcd, the camera can be easily repared by removing the back cover and than loosening the conectors and replacing the motherboard,there is no use in removing the lcd.
The screws (in orange) near the swivel base are shorter, 2.5mm. Also do not remove the screws (in red) on either side of the screen, it is unnecessary for removing the rear cover. See my comment on the next step.
rakurai - Replica
The first 4 steps aren’t necessary
Dave Common - Replica
