Introduzione
This will allow you access to the ports, or if you need to replace the dust cover, will allow you to do that.
Cosa ti serve
Use a thin piece of plastic, spudger, or fingernail (if you have them) to lift up the edge of the grip, and pull up slowly.
Repeat for the other two grips
Remove the adhesive like you would rubber cement, just rub your finger against it, it will come off.
Optionally throw the balled up adhesive at people pretending its a booger :)
Altre 8 persone hanno completato questa guida.
