Salta al contenuto principale
Canon EOS 5D Mark II Internal Speaker Replacement
Cosa ti serve
  1. Canon EOS 5D Mark II Internal Speaker Replacement, Clock Battery: passo 1, immagine 1 di 1
    • Lift the rubber flap covering the input/output jacks.
  2. Canon EOS 5D Mark II Internal Speaker Replacement: passo 2, immagine 1 di 1
    • Using a Phillips #000, remove the single 3.4 mm screw.
  3. Canon EOS 5D Mark II Internal Speaker Replacement: passo 3, immagine 1 di 1
    • This step will permanently erase all user settings.
    • The memory battery can now be easily slid out of place.
    • If you are following this guide in an effort to perform a hard reset, you should now press the shutter button multiple times in order to drain any left over power, then replace the batteries and power the device back on. You have just performed a hard reset!
  4. Canon EOS 5D Mark II Internal Speaker Replacement, Back Panel: passo 4, immagine 1 di 1
    • Peel back the rubber cover above the in/out ports to reveal two screw heads.
  5. Canon EOS 5D Mark II Internal Speaker Replacement: passo 5, immagine 1 di 1
    • Remove both 5.4 mm screws using a Phillips #0.
  6. Canon EOS 5D Mark II Internal Speaker Replacement: passo 6, immagine 1 di 1
    • Lift the in/out port plastic covering from the bottom where the backup battery used to be.
  7. Canon EOS 5D Mark II Internal Speaker Replacement: passo 7, immagine 1 di 1
    • Remove each 6.3 mm screw on either side of the viewfinder using a Phillips #0 screwdriver.
  8. Canon EOS 5D Mark II Internal Speaker Replacement: passo 8, immagine 1 di 1
    • Remove the three 4.8 mm screws on the bottom of the back plate using a Phillips #0.
  9. Canon EOS 5D Mark II Internal Speaker Replacement: passo 9, immagine 1 di 1
    • Peel back the rubber covering next to the menu dial to access the screw.
    • Remove the single 3.4 mm screw using a Phillips #0.
  10. Canon EOS 5D Mark II Internal Speaker Replacement: passo 10, immagine 1 di 1
    • The back panel can now fall off easily by turning the device upside down. Be sure to catch it so the data ribbons do not tear or tug.
  11. Canon EOS 5D Mark II Internal Speaker Replacement: passo 11, immagine 1 di 1
    • Remove each data ribbon cable from the motherboard by applying pressure down towards the motherboard and gently sliding your thumb upwards on the slot where the cable meets the motherboard. This will raise a very small clip that locks the cable in place.
    • The back panel is now free from the rest of the device.
  12. Canon EOS 5D Mark II Internal Speaker Replacement, LCD: passo 12, immagine 1 di 3 Canon EOS 5D Mark II Internal Speaker Replacement, LCD: passo 12, immagine 2 di 3 Canon EOS 5D Mark II Internal Speaker Replacement, LCD: passo 12, immagine 3 di 3
    • Remove each of the 3.4 mm screws holding in the LCD using a Phillips #0.
  13. Canon EOS 5D Mark II Internal Speaker Replacement: passo 13, immagine 1 di 1
    • Grip the wire attaching the speaker to the data ribbon cable and pull it out.
    • The LCD is now free from the back panel.
  14. Canon EOS 5D Mark II Internal Speaker Replacement, Internal Speaker: passo 14, immagine 1 di 1
    • Remove the single 4.8 mm screw using a Phillips #0.
  15. Canon EOS 5D Mark II Internal Speaker Replacement: passo 15, immagine 1 di 1
    • Remove the speaker by firmly gripping the top of the speaker and pulling down towards the bottom of the back panel while rotating the top of the speaker upwards, away from the back panel. This will allow the speaker to come off of its pivot point.
Conclusione
Altre 2 persone hanno completato questa guida.
Mike Seed
Membro da: 09/22/14
2.956 Reputazione
8 Guide realizzate
USF Tampa, Team 1-6, Hickman Fall 2014 Membro di USF Tampa, Team 1-6, Hickman Fall 2014
USFT-HICKMAN-F14S1G6
3 Membri
16 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 11
Tutti i Tempi: 1,908
