Salta al contenuto principale
Canon EOS 5D Mark II Front Panel Replacement
Cosa ti serve
  1. Canon EOS 5D Mark II Front Panel Replacement, Back Panel: passo 1, immagine 1 di 1
    • Peel back the rubber cover above the in/out ports to reveal two screw heads.
  2. Canon EOS 5D Mark II Front Panel Replacement: passo 2, immagine 1 di 1
    • Remove both 5.4 mm screws using a Phillips #0.
  3. Canon EOS 5D Mark II Front Panel Replacement: passo 3, immagine 1 di 1
    • Lift the in/out port plastic covering from the bottom where the backup battery used to be.
  4. Canon EOS 5D Mark II Front Panel Replacement: passo 4, immagine 1 di 1
    • Remove each 6.3 mm screw on either side of the viewfinder using a Phillips #0 screwdriver.
  5. Canon EOS 5D Mark II Front Panel Replacement: passo 5, immagine 1 di 1
    • Remove the three 4.8 mm screws on the bottom of the back plate using a Phillips #0.
  6. Canon EOS 5D Mark II Front Panel Replacement: passo 6, immagine 1 di 1
    • Peel back the rubber covering next to the menu dial to access the screw.
    • Remove the single 3.4 mm screw using a Phillips #0.
  7. Canon EOS 5D Mark II Front Panel Replacement: passo 7, immagine 1 di 1
    • The back panel can now fall off easily by turning the device upside down. Be sure to catch it so the data ribbons do not tear or tug.
  8. Canon EOS 5D Mark II Front Panel Replacement: passo 8, immagine 1 di 1
    • Remove each data ribbon cable from the motherboard by applying pressure down towards the motherboard and gently sliding your thumb upwards on the slot where the cable meets the motherboard. This will raise a very small clip that locks the cable in place.
    • The back panel is now free from the rest of the device.
  9. Canon EOS 5D Mark II Front Panel Replacement, Front Panel: passo 9, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • Using tweezers, pull out the wire attaching the front panel to the motherboard.
  10. Canon EOS 5D Mark II Front Panel Replacement: passo 10, immagine 1 di 1
    • Peel off the rubber cover on the front panel in order to access the screws underneath.
  11. Canon EOS 5D Mark II Front Panel Replacement: passo 11, immagine 1 di 1
    • Remove each of the 4.9 mm three screws using a Phillips #0.
  12. Canon EOS 5D Mark II Front Panel Replacement: passo 12, immagine 1 di 1
    • Remove the two 4.8 mm screws above where the lens would be using a Phillips #0.
  13. Canon EOS 5D Mark II Front Panel Replacement: passo 13, immagine 1 di 1
    • Remove the single screw underneath where the lens would be using a Phillips #0.
  14. Canon EOS 5D Mark II Front Panel Replacement: passo 14, immagine 1 di 3 Canon EOS 5D Mark II Front Panel Replacement: passo 14, immagine 2 di 3 Canon EOS 5D Mark II Front Panel Replacement: passo 14, immagine 3 di 3
    • Remove the four 3.0 mm screws next to the memory card reader using a Phillips #0.
  15. Canon EOS 5D Mark II Front Panel Replacement: passo 15, immagine 1 di 2 Canon EOS 5D Mark II Front Panel Replacement: passo 15, immagine 2 di 2
    • Remove the front panel by lifting upwards from the right side where the in/out ports used to be.
Conclusione
Altre 14 persone hanno completato questa guida.
Mike Seed
Membro da: 09/22/14
3.115 Reputazione
8 Guide realizzate
USF Tampa, Team 1-6, Hickman Fall 2014 Membro di USF Tampa, Team 1-6, Hickman Fall 2014
USFT-HICKMAN-F14S1G6
3 Membri
17 Guide realizzate
1Commento della guida
Good write-up. I just replaced my casing using these instructions.
sebastien - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 77
Tutti i Tempi: 11,964
