Salta al contenuto principale
Canon EOS 5D Mark II Back Panel Replacement
Cosa ti serve
  1. Canon EOS 5D Mark II Back Panel Replacement, Clock Battery: passo 1, immagine 1 di 1
    • Lift the rubber flap covering the input/output jacks.
  2. Canon EOS 5D Mark II Back Panel Replacement: passo 2, immagine 1 di 1
    • Using a Phillips #000, remove the single 3.4 mm screw.
  3. Canon EOS 5D Mark II Back Panel Replacement: passo 3, immagine 1 di 1
    • This step will permanently erase all user settings.
    • The memory battery can now be easily slid out of place.
    • If you are following this guide in an effort to perform a hard reset, you should now press the shutter button multiple times in order to drain any left over power, then replace the batteries and power the device back on. You have just performed a hard reset!
  4. Canon EOS 5D Mark II Back Panel Replacement, Back Panel: passo 4, immagine 1 di 1
    • Peel back the rubber cover above the in/out ports to reveal two screw heads.
  5. Canon EOS 5D Mark II Back Panel Replacement: passo 5, immagine 1 di 1
    • Remove both 5.4 mm screws using a Phillips #0.
  6. Canon EOS 5D Mark II Back Panel Replacement: passo 6, immagine 1 di 1
    • Lift the in/out port plastic covering from the bottom where the backup battery used to be.
  7. Canon EOS 5D Mark II Back Panel Replacement: passo 7, immagine 1 di 1
    • Remove each 6.3 mm screw on either side of the viewfinder using a Phillips #0 screwdriver.
  8. Canon EOS 5D Mark II Back Panel Replacement: passo 8, immagine 1 di 1
    • Remove the three 4.8 mm screws on the bottom of the back plate using a Phillips #0.
  9. Canon EOS 5D Mark II Back Panel Replacement: passo 9, immagine 1 di 1
    • Peel back the rubber covering next to the menu dial to access the screw.
    • Remove the single 3.4 mm screw using a Phillips #0.
  10. Canon EOS 5D Mark II Back Panel Replacement: passo 10, immagine 1 di 1
    • The back panel can now fall off easily by turning the device upside down. Be sure to catch it so the data ribbons do not tear or tug.
  11. Canon EOS 5D Mark II Back Panel Replacement: passo 11, immagine 1 di 1
    • Remove each data ribbon cable from the motherboard by applying pressure down towards the motherboard and gently sliding your thumb upwards on the slot where the cable meets the motherboard. This will raise a very small clip that locks the cable in place.
    • The back panel is now free from the rest of the device.
Conclusione
Altre 15 persone hanno completato questa guida.
Mike Seed
Membro da: 09/22/14
3.115 Reputazione
8 Guide realizzate
USF Tampa, Team 1-6, Hickman Fall 2014 Membro di USF Tampa, Team 1-6, Hickman Fall 2014
USFT-HICKMAN-F14S1G6
3 Membri
17 Guide realizzate
2Commenti sulla guida
To replace the LCD would you just replace the full back panel?
Maura - Replica
I had a loose back panel on my EOS 5d and your pictures and instructions gave me the courage to peel back the rubber and tighten screw (was out of its hole) and viola. No more squeak. Thanks so much for your pictorial. Best, John M
jdmiller41 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 78
Tutti i Tempi: 11,452
