Salta al contenuto principale
Canon EOS 40D Shutter Assembly Replacement
Cosa ti serve
  1. Canon EOS 40D Shutter Assembly Replacement, Shutter Assembly: passo 1, immagine 1 di 1
    • Get the Canon 40D Service Repair Manual
    • Have a clean and organized workspace. I labelled plastic trays by step number and put all items for each step in a separate tray.
    • Watch a couple Youtube videos on this process
  2. Canon EOS 40D Shutter Assembly Replacement: passo 2, immagine 1 di 2 Canon EOS 40D Shutter Assembly Replacement: passo 2, immagine 2 di 2
    • Peel off rubber grips
  3. Canon EOS 40D Shutter Assembly Replacement: passo 3, immagine 1 di 1
    • take off front piece
  4. Canon EOS 40D Shutter Assembly Replacement: passo 4, immagine 1 di 2 Canon EOS 40D Shutter Assembly Replacement: passo 4, immagine 2 di 2
    • take off rear
    • connectors disconnect by flipping black/brown tab up and sliding plastic tab out.
  5. Canon EOS 40D Shutter Assembly Replacement: passo 5, immagine 1 di 3 Canon EOS 40D Shutter Assembly Replacement: passo 5, immagine 2 di 3 Canon EOS 40D Shutter Assembly Replacement: passo 5, immagine 3 di 3
    • Take off top cover
  6. Canon EOS 40D Shutter Assembly Replacement: passo 6, immagine 1 di 3 Canon EOS 40D Shutter Assembly Replacement: passo 6, immagine 2 di 3 Canon EOS 40D Shutter Assembly Replacement: passo 6, immagine 3 di 3
    • take off bottom plate
    • disconnect and remove bottom board
  7. Canon EOS 40D Shutter Assembly Replacement: passo 7, immagine 1 di 1
    • remove CMOS assembly
  8. Canon EOS 40D Shutter Assembly Replacement: passo 8, immagine 1 di 1
    • remove metal back
    • remove and replace shutter assembly, transfering components that aren't on the new one
Conclusione
Altre 6 persone hanno completato questa guida.
2 Commenti
how do you replace the bridge (male portion on camera) other than putting the card in a card reader
wareibevictoriap - Replica
how to replace the focus lock beeper
Dave Reitner - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 58
Tutti i Tempi: 7,180
