Salta al contenuto principale
Canon EOS 40D Flash Hot Shoe Replacement
Cosa ti serve
  1. Canon EOS 40D Flash Hot Shoe Replacement, Battery: passo 1, immagine 1 di 1
    • Locate the battery compartment cover on the bottom of the camera below the shutter button.
  2. Canon EOS 40D Flash Hot Shoe Replacement: passo 2, immagine 1 di 1
    • Find the marked arrow on the battery compartment cover labeled "BATT. OPEN". Slide the lever following the arrow's direction and lift at the same time to release the latch.
  3. Canon EOS 40D Flash Hot Shoe Replacement: passo 3, immagine 1 di 1
    • Release the lever and allow the battery compartment cover to completely open.
    • Remove the battery.
  4. Canon EOS 40D Flash Hot Shoe Replacement, Flash Hot Shoe: passo 4, immagine 1 di 3 Canon EOS 40D Flash Hot Shoe Replacement, Flash Hot Shoe: passo 4, immagine 2 di 3 Canon EOS 40D Flash Hot Shoe Replacement, Flash Hot Shoe: passo 4, immagine 3 di 3
    • Use a metal spudger or opening tool to gently lift the hotshoe plate and slide it off.
  5. Canon EOS 40D Flash Hot Shoe Replacement: passo 5, immagine 1 di 3 Canon EOS 40D Flash Hot Shoe Replacement: passo 5, immagine 2 di 3 Canon EOS 40D Flash Hot Shoe Replacement: passo 5, immagine 3 di 3
    • Remove the four 4.0 mm Phillips #000 screws securing the flash shoe to the camera.
    • Remove the flash shoe.
Conclusione
Altre 4 persone hanno completato questa guida.
USF Tampa, Team 12-3, Blackwell Fall 2015 Membro di USF Tampa, Team 12-3, Blackwell Fall 2015
USFT-BLACKWELL-F15S12G3
4 Membri
16 Guide realizzate
Un commento
This is the best down to earth instructions i have ever had. No messing about even tells what screws and how to open the battery cover
Albert
albert irving - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 27
Tutti i Tempi: 4,461
