Salta al contenuto principale
Canon EOS 300 Top Panel Replacement
Cosa ti serve
  1. Canon EOS 300 Top Panel Replacement, Batteries: passo 1, immagine 1 di 3 Canon EOS 300 Top Panel Replacement, Batteries: passo 1, immagine 2 di 3 Canon EOS 300 Top Panel Replacement, Batteries: passo 1, immagine 3 di 3
    • Open up the battery door.
  2. Canon EOS 300 Top Panel Replacement: passo 2, immagine 1 di 2 Canon EOS 300 Top Panel Replacement: passo 2, immagine 2 di 2
    • Remove the batteries from the camera by sliding them out into your palm.
  3. Canon EOS 300 Top Panel Replacement, Side Panel with Lever: passo 3, immagine 1 di 2 Canon EOS 300 Top Panel Replacement, Side Panel with Lever: passo 3, immagine 2 di 2
    • Release the side latch to open the back panel.
  4. Canon EOS 300 Top Panel Replacement: passo 4, immagine 1 di 2 Canon EOS 300 Top Panel Replacement: passo 4, immagine 2 di 2
    • Remove the two black 4.5mm screws above and below the latch.
  5. Canon EOS 300 Top Panel Replacement: passo 5, immagine 1 di 2 Canon EOS 300 Top Panel Replacement: passo 5, immagine 2 di 2
    • Using your finger, carefully pry open the side panel from the top of camera.
    • Pull panel downwards to remove.
    • Make sure to keep track of the small black piece of rubber under the latch.
  6. Canon EOS 300 Top Panel Replacement, Front Panel: passo 6, immagine 1 di 2 Canon EOS 300 Top Panel Replacement, Front Panel: passo 6, immagine 2 di 2
    • Remove the two silver 6mm Phillips #1 screws.
  7. Canon EOS 300 Top Panel Replacement: passo 7, immagine 1 di 2 Canon EOS 300 Top Panel Replacement: passo 7, immagine 2 di 2
    • Flip camera over to the bottom.
    • Remove the one 5mm Phillips #1 silver screw.
  8. Canon EOS 300 Top Panel Replacement: passo 8, immagine 1 di 2 Canon EOS 300 Top Panel Replacement: passo 8, immagine 2 di 2
    • Remove the front panel by pulling away from the side with the lever.
  9. Canon EOS 300 Top Panel Replacement, Bottom Panel: passo 9, immagine 1 di 2 Canon EOS 300 Top Panel Replacement, Bottom Panel: passo 9, immagine 2 di 2
    • Remove three black 7.3mm Phillips #1 screws located on the corners of the camera.
    • Remove five black 4.8mm Phillips #1 screws.
  10. Canon EOS 300 Top Panel Replacement: passo 10, immagine 1 di 3 Canon EOS 300 Top Panel Replacement: passo 10, immagine 2 di 3 Canon EOS 300 Top Panel Replacement: passo 10, immagine 3 di 3
    • Simply remove the bottom panel by prying it off with your finger.
    • When removing the panel, be sure the bottom of the camera is facing upright. There are loose gears that may fall out.
    • Be wary of a loose piece of foam attached to the bottom panel.
  11. Canon EOS 300 Top Panel Replacement, Side Panel with Grip: passo 11, immagine 1 di 3 Canon EOS 300 Top Panel Replacement, Side Panel with Grip: passo 11, immagine 2 di 3 Canon EOS 300 Top Panel Replacement, Side Panel with Grip: passo 11, immagine 3 di 3
    • Remove the remote control socket cover.
  12. Canon EOS 300 Top Panel Replacement: passo 12, immagine 1 di 2 Canon EOS 300 Top Panel Replacement: passo 12, immagine 2 di 2
    • Remove two black 4.5mm Phillips #1 screws.
  13. Canon EOS 300 Top Panel Replacement: passo 13, immagine 1 di 2 Canon EOS 300 Top Panel Replacement: passo 13, immagine 2 di 2
    • Remove two black 4.8mm Phillips #1 screws on the front of the camera.
  14. Canon EOS 300 Top Panel Replacement: passo 14, immagine 1 di 2 Canon EOS 300 Top Panel Replacement: passo 14, immagine 2 di 2
    • Pry open the side grip using a spudger.
  15. Canon EOS 300 Top Panel Replacement, Eyecup: passo 15, immagine 1 di 2 Canon EOS 300 Top Panel Replacement, Eyecup: passo 15, immagine 2 di 2
    • With your hands, remove the rubber grip from the eye piece.
  16. Canon EOS 300 Top Panel Replacement: passo 16, immagine 1 di 1
    • Remove the eyecup from the eyepiece by pushing the eyecup up.
  17. Canon EOS 300 Top Panel Replacement, Top Panel: passo 17, immagine 1 di 2 Canon EOS 300 Top Panel Replacement, Top Panel: passo 17, immagine 2 di 2
    • Remove two silver 5.0mm Phillips #1 screws.
  18. Canon EOS 300 Top Panel Replacement: passo 18, immagine 1 di 1
    • Remove the silver 5.5mm Phillips #1 screw.
  19. Canon EOS 300 Top Panel Replacement: passo 19, immagine 1 di 2 Canon EOS 300 Top Panel Replacement: passo 19, immagine 2 di 2
    • Pry the top silver part of the camera off.
    • Buttons may slip out of the camera's top as the top is pulled off the camera (shown in picture two).
Conclusione
Altre 2 persone hanno completato questa guida.
Tammy Kong
Membro da: 01/23/14
771 Reputazione
6 Guide realizzate
Cal Poly, Team 6-20, Maness Winter 2014 Membro di Cal Poly, Team 6-20, Maness Winter 2014
CPSU-MANESS-W14S6G20
4 Membri
32 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 19
Ultimi 30 Giorni: 36
Tutti i Tempi: 946
