Introduzione
The bottom panel can be easily removed, and allows access for replacement on other parts of the camera.
Cosa ti serve
Remove the front panel by pulling away from the side with the lever.
Remove three black 7.3mm Phillips #1 screws located on the corners of the camera.
Remove five black 4.8mm Phillips #1 screws.
1Commento della guida
muy buena la explicacion de como desmontar la maquina. Te has gadano los 30 puntos
