Salta al contenuto principale
Canon EOS 30 lnner Eyepiece Replacement
Cosa ti serve
  1. Canon EOS 30 lnner Eyepiece Replacement, Front Panel: passo 1, immagine 1 di 1
    • Remove the two 4.8 mm black screws above the lens on the front of the camera.
  2. Canon EOS 30 lnner Eyepiece Replacement: passo 2, immagine 1 di 1
    • Remove the 4.3 mm black screw under the lens ring, and the 4.8 mm black screw under the camera.
  3. Canon EOS 30 lnner Eyepiece Replacement: passo 3, immagine 1 di 1
    • Remove the 4.8 mm black screw on the left side of the camera.
  4. Canon EOS 30 lnner Eyepiece Replacement: passo 4, immagine 1 di 1
    • Remove the front panel by lifting it away from the camera's body.
  5. Canon EOS 30 lnner Eyepiece Replacement, Top Panel: passo 5, immagine 1 di 1
    • Slide the outer eyepiece upward to remove it.
  6. Canon EOS 30 lnner Eyepiece Replacement: passo 6, immagine 1 di 1
    • Remove the two 4.75 mm black screws located on the top of the camera.
  7. Canon EOS 30 lnner Eyepiece Replacement: passo 7, immagine 1 di 1
    • Remove the four 4.3 mm black screws near the bottom corners of the eyepiece at the back of the camera.
  8. Canon EOS 30 lnner Eyepiece Replacement: passo 8, immagine 1 di 2 Canon EOS 30 lnner Eyepiece Replacement: passo 8, immagine 2 di 2
    • Slowly separate the top panel from the camera by pushing it upward.
    • Separating the top panel too far or quickly can damage the ribbon cable and connecting wires that are still attached to the top panel of the camera.
  9. Canon EOS 30 lnner Eyepiece Replacement, The Inner Eyepiece: passo 9, immagine 1 di 1
    • Remove the two 9.5 mm black screws that attach the inner eyepiece to the camera's body and remove the eyepiece.
  10. Canon EOS 30 lnner Eyepiece Replacement: passo 10, immagine 1 di 1
    • Remove the two 4.3 mm silver screws on each side of the inner eyepiece.
  11. Canon EOS 30 lnner Eyepiece Replacement: passo 11, immagine 1 di 1
    • Separate the inner eyepiece into three parts.
    • The outer piece (left) has a small gear, which can easily fall off and get lost.
  12. Canon EOS 30 lnner Eyepiece Replacement: passo 12, immagine 1 di 1
    • Remove the two 3.6 mm black screws from the outer piece.
  13. Canon EOS 30 lnner Eyepiece Replacement: passo 13, immagine 1 di 1
    • Remove the glass panel and replace it.
    • When removing the glass panel make sure not to separate the small rubber piece attached around the frame.
Conclusione
Altre 5 persone hanno completato questa guida.
Jackie
Membro da: 04/17/11
236 Reputazione
3 Guide realizzate
Cal Poly, Team 8-8, Regan Spring 2011 Membro di Cal Poly, Team 8-8, Regan Spring 2011
CPSU-REGAN-S11S8G8
5 Membri
22 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 12
Tutti i Tempi: 3,146
