Introduzione
This guide will show you how to access, remove, and replace the LCD screen. The process is safe and uncomplicated.
Cosa ti serve
Remove the two 4.8 mm black screws above the lens on the front of the camera.
Remove the front panel by lifting it away from the camera's body.
To unclip gold connector push the edge up and away from the lcd screen. A plastic opening tool is recommended.
The gold connector can fall into the camera, but it will remain attached and can be pulled back up.
Altre 2 persone hanno completato questa guida.
