Salta al contenuto principale
Canon ELPH Z3 Camera Image Sensor Replacement
Cosa ti serve
  1. Canon ELPH Z3 Camera Image Sensor Replacement, Shutter Button: passo 1, immagine 1 di 3 Canon ELPH Z3 Camera Image Sensor Replacement, Shutter Button: passo 1, immagine 2 di 3 Canon ELPH Z3 Camera Image Sensor Replacement, Shutter Button: passo 1, immagine 3 di 3
    • Unscrew the 7 4.1mm screws around the camera using a PH000 screwdriver.
  2. Canon ELPH Z3 Camera Image Sensor Replacement: passo 2, immagine 1 di 3 Canon ELPH Z3 Camera Image Sensor Replacement: passo 2, immagine 2 di 3 Canon ELPH Z3 Camera Image Sensor Replacement: passo 2, immagine 3 di 3
    • Split the front and back coverings of the camera.
    • Remove the back covering completely.
    • This allows for easier access to the shutter button carrier.
  3. Canon ELPH Z3 Camera Image Sensor Replacement: passo 3, immagine 1 di 2 Canon ELPH Z3 Camera Image Sensor Replacement: passo 3, immagine 2 di 2
    • Slide the shutter button carrier off of the camera.
    • Notice shutter button is on the right hand side of the carrier.
  4. Canon ELPH Z3 Camera Image Sensor Replacement: passo 4, immagine 1 di 3 Canon ELPH Z3 Camera Image Sensor Replacement: passo 4, immagine 2 di 3 Canon ELPH Z3 Camera Image Sensor Replacement: passo 4, immagine 3 di 3
    • Press upward on the shutter button from the underside of the carrier by using your thumb.
    • Separate the shutter button from the carrier.
  5. Canon ELPH Z3 Camera Image Sensor Replacement, Rear Screen: passo 5, immagine 1 di 2 Canon ELPH Z3 Camera Image Sensor Replacement, Rear Screen: passo 5, immagine 2 di 2
    • Pull apart the front and back coverings of the camera.
    • Remove the back covering completely to gain access of the rear screen.
  6. Canon ELPH Z3 Camera Image Sensor Replacement: passo 6, immagine 1 di 3 Canon ELPH Z3 Camera Image Sensor Replacement: passo 6, immagine 2 di 3 Canon ELPH Z3 Camera Image Sensor Replacement: passo 6, immagine 3 di 3
    • Unscrew the 6 4.1mm screws that are holding the back screen in place by using the PH000 screwdriver.
    • This step may require for you to pull back tape to gain access to some screws.
  7. Canon ELPH Z3 Camera Image Sensor Replacement: passo 7, immagine 1 di 2 Canon ELPH Z3 Camera Image Sensor Replacement: passo 7, immagine 2 di 2
    • Pull the yellow tape away from the side that is attached to the back screen.
    • Remove the back screen.
  8. Canon ELPH Z3 Camera Image Sensor Replacement, Image Sensor: passo 8, immagine 1 di 3 Canon ELPH Z3 Camera Image Sensor Replacement, Image Sensor: passo 8, immagine 2 di 3 Canon ELPH Z3 Camera Image Sensor Replacement, Image Sensor: passo 8, immagine 3 di 3
    • Pull away back screen base to reveal the image sensor.
    • Remove image sensor using a set of pliers.
Conclusione
Katy Skillings
Membro da: 10/21/16
1 Reputazione
2 Guide realizzate
UMass Dartmouth, Team 1-7, Catania Fall 2016 Membro di UMass Dartmouth, Team 1-7, Catania Fall 2016
UMASSD-CATANIA-F16S1G7
3 Membri
10 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 399
