Salta al contenuto principale
Canon ELPH Z3 Camera Battery Replacement
  1. Canon ELPH Z3 Camera Battery  Replacement, Battery: passo 1, immagine 1 di 3 Canon ELPH Z3 Camera Battery  Replacement, Battery: passo 1, immagine 2 di 3 Canon ELPH Z3 Camera Battery  Replacement, Battery: passo 1, immagine 3 di 3
    • Place the camera face down on a flat surface ( lens facing down).
    • Press firmly on the battery latch that is marked.
    • Slide the battery latch to the right to expose battery.
    • Detach the battery latch completely from the camera.
  2. Canon ELPH Z3 Camera Battery  Replacement: passo 2, immagine 1 di 2 Canon ELPH Z3 Camera Battery  Replacement: passo 2, immagine 2 di 2
    • If the battery is leaking acid. Please proceed with extreme caution. You may sustain injury!
    • Remove the battery with a piece of double sided tape if it is leaking.
    • Use a Q-tip with a small amount of rubbing alcohol to clean battery connections.
    • Remove the existing battery using your fingers.
Conclusione
UMass Dartmouth, Team 1-7, Catania Fall 2016 Membro di UMass Dartmouth, Team 1-7, Catania Fall 2016
UMASSD-CATANIA-F16S1G7
3 Membri
10 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 13
Tutti i Tempi: 1,037
